TPI bolts for the runner.
I replaced the injectors in my TPI engine and I have two long bolt that I can not figure out where I took them out on my runners. If anybody can help me out or have been through this please I need your help.
Re: TPI bolts for the runner.
eseibel67 Thanks for the reply back. I did not remove those bolts from their area. Just so I would not get them mixed up. I am going to have to take everything back apart and figure out where I went wrong. lol
Thanks to all that helped. It is dark by the time I get off work. So I will take a look at it on the weekend and let you know how things go.
COTM Editor (Retired)
They are probably the two runner bolts that are accessed from the inboard side if the intake.
i've taken my **** appart more times than i care to count over the last year. the two extra long ones are the ones that screw in from the inside. then, on mine, there is one that seems a little longer than the rest, but not quite as long as the two inner ones. that one was originally removed from the passenger side-front-top on my car, but honestly, i dont think it matters, and it will likely fit in any of the outter holes.
hope this helps.
also, it can be trickier than it seems to get a vacuum leak-free seal on the runners (especially at the bottom.) i was finally able to achieve a 100%, smoke machine tested, vacuum leak-free installation by doubling up on the runner gaskets.
evilstuie
01-09-2020 08:29 PM
ambainb
04-25-2016 09:21 PM
LT1Formula
20
11-14-2015 12:02 AM
Sanjay
08-12-2015 03:41 PM
