#5 cylinder header glowing
Car: 1988 gta se
Engine: 5.0 tpi
Transmission: man
Hey guys, I have a 1988 gta ,a new zz430 engine ,hsr intake 24lb hr. injectors ,msd 6al box ,it has about 1 hr. of run time why would the #5 header glow? I've switched injectors, plugs, checked valve lash, checked for vacuum leaks, checked injector pulse , set timing to 10 deg. I'm stumped !any suggestions?
Re: #5 cylinder header glowing
Gotta be running lean in that one cylinder. Injector or vacuum leak.
Engine: 4++,350 & 305 CIs
Inj hanging open and burning fuel in the exhaust?
Fuel psi regulator diafram ok? Not sucking fuel through the vac line?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Vacuum leak on that runner?
Car: 1988 gta se
Engine: 5.0 tpi
Transmission: man
hey guys thank you for your suggestions, after a ton of time (money)I found out all cylinders would glow 5 was just first. so there is to much motor for hypertech chip (junk waste of 300.00)I order a custom prom will let you know how it turns out
A stock 350 chip is better than the hypercrap..
Chad Speier
09-24-2015 12:32 PM
