89 383 TPI stumbling idle
Old 06-06-2015, 02:17 PM
dtedrow's Avatar
Car: 1989 pontiac firebird trans am GTA
Engine: TPI 350
Transmission: auto 700r4
Axle/Gears: borg warner 9 bolt and 3.27
i have a 89 TA, I have a new prom chip for it, the car starts up fine and idles just fine for a few minutes then u give it some throttle then drop back down to idle and then it acts like it cant hold idle and stumbles and then catches, then dies, it idles right round 1000, advance timing is 29 degrees at idle, o2 is working and all my sensors are, I have no check engine light even when it dies, itll for no reason drop down to round 500 then die, timing while at 500 is 16 degrees, lean afr, I have a new msd cap, rotor, Mallory ignition module, msd coil, and I just put a new esc module in, im thinking its a electrical issue but I need someone with more experience to chim in
Old 06-12-2015, 06:02 PM
killer777's Avatar
Car: 1989 Firebird Trans Am
Engine: 355
Re: 89 383 TPI stumbling idle
What chip? Sounds like it's getting too much fuel or not enough. Did you check fuel pressure? Ohm the injectors?
armybyrd
12-05-2015 09:22 AM
mdtoren
08-16-2015 05:45 PM
85Iroc-Z
08-13-2015 01:58 AM
Sanjay
08-12-2015 03:41 PM
Quick Reply: 89 383 TPI stumbling idle
