Fuel leaking from AFPR port
Old 09-28-2015, 11:14 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
In the quest to fix an intermittent hard starting problem as well as rough idle, I discovered that fuel was leaking from the AFPR when I took the vac line off the port. Seems as though this is a broken diaphragm in there.
My question is do I simply buy a replacement AFPR? Or do I need to buy a new diaphragm for underneath the AFPR? I'm not sure if AFPR comes with everything I need. Or if they're simply an adjustment tool for the factory diaphragm.
I see AC Delco has a # 2142156 that is listed as a replacement for my car. But it's just a spring and diaphragm.
Old 09-29-2015, 07:07 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Fuel leaking from AFPR port
Yup, that is the tell-tale sign of a perforated/ripper diaphragm. You just need the diaphragm vs new AFPR.
I don't know if any/all/none AFPRs come with a replacement diaphragm either.
Old 10-10-2015, 09:56 PM
Car: 1989 GTA
All is well again. The adjustable fuel pressure regulator is really just a cover for the spring and diaphragm. The AC Delco part above solved the problem.
Infested
05-22-2018 11:56 PM
LT1Formula
20
11-14-2015 12:02 AM
wayshegoes
08-17-2015 12:00 PM
86White_T/A305
08-17-2015 12:16 AM
Kaweh
08-09-2015 02:54 PM
Quick Reply: Fuel leaking from AFPR port
