My camaro won't strat
Car: 86 I roc-z
Engine: 5.0
Transmission: 700
My 86 I roc-z tpi 305 won't start I need help the car was fine The last time I drove it then Monday I went to start it it tuner over but no start plz help I'm thinking about doing a swap to carb if I can't get the car running soon
1 Post
Car: 1991 Z28 1LE
Re: My camaro won't strat
Check the basics, fuel pressure (44psi+/-), spark, fuel injectors pulsing.
Quick check I usually tell most people with no start is to watch the tach during crank, it should bounce, if it is completely still than your distributor is not sending a pulse signal to the ECM.
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Think about that.
I'm going to go out on a limb here and say it's easier to fix your current problem than to introduce new ones by trying to do a carb swap.
You gave no indication of the following. This basic info is required for anyone to help you...
- Fuel Pressure
- no fuel pressure gauge, ok... did you at least hear the fuel pump prime?
- Is the Security light staying illuminated on the dash? You should be Pre-VATS so I have a feeling this won't affect you.
- Spark?
Car: 86 I roc-z
Engine: 5.0
Transmission: 700
Sorry for not giveing enough information about the car. No pre vat It's
a stock 86 tpi 305. Things I checked yes my fuel pump come on fuel pressure was 45psi. Each fuel injectors ohms was 16 I have pulse. ignition module is gd. Things I changed ecm. Cap and rotor ignition coil
1 Post
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Pull one of your plugs, leave it in the spark plug wire, hold it to a metal piece on body, have someone crank the car while you watch. You should see a visible spark. If you dont, are the plugs fouled? check the wires for obvious damage. The icm failing is common, you said it is good, but how do you know, did you replace it? wires and plugs would usually make the car run rough first and cause driveability issues. not just cause it to not start overnight. Also, I know you tested the fuel system, but you should try spraying some starter fluid in there anyway, it would confirm the injectors aren't clogged or something.
Car: 86 I roc-z
Engine: 5.0
Transmission: 700
1 Post
Car: 1991 Z28 1LE
You mentioned changing the ECM what year is it out of? Same PROM from your 86?
Based on your information it should run. You have proper fuel pressure, you have spark, and your injectors are pulsing. So unless your cylinders all lost compression it should run.
i bought a 1990 iroc last night it ran "ok" missed i little on the way home thought maybe just old gas. fired it up a couple times last night no problems starting. this morning to try to fire it and it wont start its turning over and will run on starter fluid but wont idle and cuts off. where do i go from here why would it crank last night but not today?
Car: 86 I roc-z
Engine: 5.0
Transmission: 700
Car: 86 I roc-z
Engine: 5.0
Transmission: 700
If it will not fire with starter fluid then you either don't have spark or your getting really weak spark.
Yes fuel pump comes on. I got it running some how. It still picks and chooses when it wants to crank. It misses a lot thought where should i start. Tune up?? Plugs wires cap and button? Or is it a vacuum nproble. It doesn't really want to idle at all. And the pedal is hesitant.
Car: 86 I roc-z
Engine: 5.0
Transmission: 700
[NC] 305 tpi LB9 for sale
86ZRESTO
05-21-2018 08:33 AM
Joseph Andres
Aftermarket Product Review
12-11-2000 03:04 PM
