Granatelli Mass Air Flow Meter adjustment, any suggestions??
Old 02-12-2017, 11:47 PM
Johnny*G's Avatar
Car: 1987 Trans Am
Engine: 355 Edel Int, SLP, Edel heders 8PSI
Axle/Gears: 3.45 Borg Warner
Anyone ever mess with the Granatelli mAF adjustment? Mine came used and i have no idea where the setting is. Car seems to run ok but i want to be sure. I have an '87 with a supercharged L98. Do i need a 5 gas analyzer? Or can i do it by g/sec? I have a basic obd 1 scanner that does give live data. Just seeing if anyone here has used this successfully.
Old 02-13-2017, 03:04 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Re: Granatelli Mass Air Flow Meter adjustment, any suggestions??
I'll be interested too!!
I got so much error codes all the time, I returned to the original Bosch maf, fine since...
Old 02-13-2017, 11:53 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
8gps at idle is where I'd set it.
Old 02-13-2017, 12:08 PM
I'm sorry, what is 8GPS..
Old 02-13-2017, 12:12 PM
Engine: Lb9
Transmission: M20
Grams per second, idle on a stock engine is usually 8-9 gps.
If the maf maxes out too soon 255gps you might consider blowerworks maf.
http://www.blowerworks.net/sensor.html
Old 02-13-2017, 12:13 PM
How do you measure that?
Old 02-13-2017, 12:16 PM
Engine: Lb9
Transmission: M20
On a scanner or with tunerpro rt.
http://m.ebay.com/itm/162393973869?_...:7&_mwBanner=1
http://www.tunerpro.net
http://www.reddevilriver.com/site/4b...aldl.html#2625
Old 02-13-2017, 01:14 PM
Johnny*G's Avatar
Car: 1987 Trans Am
perfect! thank you for taking the time to clarify. i will double check it tonight!
