Removing transmission, can torque converter be left on engine?
Old 08-26-2010, 02:25 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Here's my situation/problem, I am removing my transmission because While swapping engines I put the torque converter in wrong(didn't engage the oil pump/rotor) because of this I cannot rotate the engine, but everything I've read says to pull transmission and torque converter together, and I am worried that if I do not I might mess up the splines, so I need some input on the best way to proceed here...
Old 08-26-2010, 02:27 PM
Project-RS's Avatar
Re: Removing transmission, can torque converter be left on engine?
i would unbolt the converter from the flywheel and drop the tranny. its alot easier that way.
Old 08-26-2010, 02:30 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Same here.
Old 08-26-2010, 02:32 PM
Project-RS's Avatar
when installing the converter. you will hear 2 clicks. if you dont hear 2 then pull it off and try again.
Old 08-26-2010, 02:45 PM
Engine: 3.8, 3.4
You guys are forgetting I can't unbolt the torque converter If I can't rotate the crank to get to all the bolts...
Old 08-26-2010, 02:50 PM
Project-RS's Avatar
well in that case. i would disconnect the driveshaft, crossmember that holds the transmission mount. and unbolt the tranny from the block. if the camaro is high enough, you can try to slide the transmission away from it.
Old 08-26-2010, 04:33 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Why not? Seized engine?
Old 08-26-2010, 04:54 PM
Engine: 3.8, 3.4
"While swapping engines I put the torque converter in wrong(didn't engage the oil pump/rotor) because of this I cannot rotate the engine"
Would like to keep the damage and repair bill to a minimum..
Old 08-26-2010, 09:31 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
If you cant rotate the torque converter while its connected to the engine how are you going to get it out of the trans if its seized that bad? First try and remove your spark plugs that will get rid of engine compression and you should be able to rotate it with a flywheel bar, oh yea make sure tranny is in neutral.
Old 08-26-2010, 10:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With a seized engine, the only way you can get the tranny off is to leave the converter attached to the flexplate. Yours is from improper installation.
Unbolt the tranny and pull it back enough until the friction interference allows you to rotate the engine to unbolt the converter then pull the tranny back out and install the converter into the tranny properly.
When installing a converter into the transmission, there are 3 stops or clicks before it's fully seated. When installing the transmission, the converter should spin freely and needs to be pulled toward the flexplate about 1/8" after the bellhousing bolts are installed. If the converter binds against the flexplate as you tighten up bellhousing bolts then the converter isn't seated properly. Pull it out and do it again.
Once you install the converter all the way into the tranny, there should be very little room on the pump side and the converter face will be well behind the bellhousing mount surface.
Old 08-27-2010, 07:18 AM
Engine: 3.8, 3.4
So pull it with torque converter after pulling it back far enough to rotate engine? Any tips on how to do this while balancing it on a floor jack with a piece of wood...my main concern is it sliding backwards off the jack once I unbolt it from the block.
Old 08-27-2010, 05:40 PM
danandamy's Avatar
Car: 86 Camaro
Just to add to the gloominess, I've never seen a case when someone cinched down the bell housing bolts with the torque converter not properly seated where it DIDN'T bust the pump in the transmission.
Dan
Old 08-27-2010, 05:42 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
very carefully, i think you'll just have to play it by ear for the balancing part. or buy one of those adapters to make your floor jack a trans jack
Old 08-27-2010, 05:53 PM
Engine: 3.8, 3.4
Dan
Yeah I'm counting on it, but hopefully I can just replace the rotor in the pump and not the whole pump, I am somewhat worried I might have bent the flexplate though, it was pinched against the block when the trans was still in it.
Old 08-29-2010, 10:08 AM
Moderator/TGO Supporter
AaronIROCZ's Avatar
Did you start the engine??? I forgot to ask when I posted in your other post. If you didn't you might be alright but I wouldn't get your hopes up. You might be able to see the pump tangs once you get the converter off the trans but it might look ok and still be broken/cracked. You would be best off to remove the pump and inspect it that way. I posted the procedure in your other post.
Vintageracer
01-10-2020 05:33 PM
Azrael91966669
25
06-20-2017 04:04 AM
bradleydeanuhl
08-12-2015 11:48 AM
3rdgenparts
08-08-2015 07:09 PM
gwade12
08-08-2015 08:17 AM
Quick Reply: Removing transmission, can torque converter be left on engine?
