shifting between gears?
Old 10-17-2013, 09:46 PM
xendr7wk's Avatar
Car: 91 z28
Transmission: 5 speed
I think that there is something wrong with my camaro :/!I dont think it should be like that, but you never know.. I need opinions from people..
How fast do you have too go to shift two second,third,fourth, and fifth gear, like saying your racing with friends just for fun.. I always have too shift from first-second like around 15/20mph..second-third 30mph... Third-fourth at 40...fourth-fifth around 50/60.. cuz if I dont shift at that certain speed, the rpms will go all the way to the red numbers like at 60rmps... I don't think its supposed to be like that..
The car is all stock!
Also I almost lost to an S10 "V6"!!STOCK! >:/!
Old 10-17-2013, 10:30 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: shifting between gears?
You shift up based on what RPM your engine will safely handle, not the road speed
If you are stupid enough to hold the revs until your engine blows up that is your fault
Old 10-18-2013, 10:31 AM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
These old cars don't have rev limiters as far as I know, at least I haven't found one on mine, but then again I don't push mine past redline.
If your looking at the speedo and shifting your doing it wrong. Every car's shift points will be at different speeds depending on final drive gearing.
When I'm driving spiritedly I usually shift around 3500 or 4000 RPMs, the L03 redlines at 5, but makes no power up high because everything flows like ****, but I have spun mine to 5K without it coming apart, with 192K on the odometer.
Old 10-18-2013, 11:29 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
What do you mean by "...have to shift..."? Why? What rpm do you shift at? Maybe you're just not used to running the engine up to where it should be for max power.
Old 10-21-2013, 12:34 PM
xendr7wk's Avatar
Car: 91 z28
the tach is not working the right way, that's why I was asking what speed is the best to shift.
Old 10-21-2013, 02:07 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
First fix the tach. But when to change gears depends on how you are driving. For normal use change up at the lowest speed without bogging the engine. Racing and you'd be changing at much higher revs and speed. Listen to the engine and feel how the car/engine handle the gear.
Old 10-21-2013, 03:04 PM
Cosmik Debris's Avatar
Is your clutch slipping, is that what you mean?
Old 10-24-2013, 02:01 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
You should be able to shift by ear. You can hear when a gear has reached its limit. Also you can feel when a car has run out of gear.(The car won't go any faster than the gear will allow.) Shift just before that.
Don't look at the tach. look at the road ahead of you and listen and stretch the gear as far as you're comfortable and shift.
Down shifting I would be careful and not be going faster than the gear can handle.
All of that is determined by your gear ratio. 3.42s and you will be reaching a gears full potential much faster. Quick shifts between gears reaching higher RPMs much faster than a lower gear ratio. What gear ratio. doyou have?
TheTraut88
09-11-2015 05:16 AM
GouldyGTR
09-07-2015 09:05 PM
TheTraut88
09-07-2015 05:22 PM
UltRoadWarrior9
09-02-2015 08:24 PM
tonys91rs
09-02-2015 07:07 PM
Quick Reply: shifting between gears?
