VSS help
Car: 82' Z28 Crossfire
Transmission: Turbo 350
VSS help
I'm not sure where to start searching for this, but I'm putting a 97 blazer overhead console in my 82 and need to have a VSS to run wire to. Problem is I have a th350 with no computer for car... How would I make this work?
Re: VSS help
if original VSS behind the speedo is not operable,could add a 2nd VSS at the speedo cable fitting on tranny(or cruise control if equipped)'82-89 camaro VSS is 2-pulse per rotation,most later GM 4 pulse/rotation,so likely need 4-pulse to properly operate '97 blazer console
Re: VSS help
http://m.summitracing.com/parts/dak-sen-01-4160
Would this work to wire to VSS wire for console??
Re: VSS help
The speedo mounted VSS is optical. Tap into that and use a conversion box. You'll need some kind of conversion since the blazer VSS signal for console more than likely isn't 8008ppm. Read everything jagsthatrun has on their site and books while you're at it.
Re: VSS help
Problem is I'm not sure I have that VSS behind speedo anymore. Anyone have a pic just to make sure? I believe its a black box but it's been a couple of years.. I saw it on a 92'. I need to pull gauges to make sure but I think they deleted mine with carb swap (think they were attempting to make a dirt track car?) so I guess I'm looking into how to add one. If anyone has a picture though that would be great to make sure I'm looking at the right thing.
TMZIrocZ350
10-07-2015 12:09 PM
