Shifting problem
Shifting problem
Hi. I have a 91' Camaro RS, with the stock 700R4. The car ran and drove fine, she's my dad's daily driver, until Saturday.
She wouldn't shift out of 1st gear, but we had reverse. He limped her home and found her fluid was a little low. Filled her up, and checked and she has no leaks.
He took her for a test drive, and he still has no gears except 1st and reverse. So he figured it was the governor and bought one off of Ebay.
It came in today and he installed it, and the car is still refusing to shift. But she goes into 2nd at high rpms.
We're wondering if we could have gotten a bad governor from ebay. It was refurbished but the green gear at the end won't turn, and according to my dad's mechanic friend, it should move freely. The original also wouldn't turn.
Thanks.
Thanks.
Re: Shifting problem
One other thing to check (requires going into the transmission oil pan) would be the springs on the accumulator valves that are with the valve body . These springs are noted for breaking and if you want to see what they look like check out my stickied thread "pictures of every component of a 700R4" .
someone972
08-30-2015 12:52 AM
