What is this thing?
Car: 1984 Firebird S/E
Engine: 1985 2.8 MPFI
Transmission: 1985 T5 5 speed manual
Axle/Gears: 3.42/4.03
What is this thing?
Morning all!
Just got my motor out and found something a bit weird. What is this thing? It's on the passenger side bank right at the back of the block above the headers. It had some sort of electrical connection to it.
Car: check
Engine: check
Transmission: check
Re: What is this thing?
My guess is that it is the dash indicator sender for engine coolant. If it had a dark green wire going to it, my guess is even more so that it is for the dash indicator.
RBob.
RBob.
Right I'll check wire colour and get back to you. Thanks again.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
No its something else I think, I know cause I unhooked it on purpose.
it and the CCP valve are both run off the same part of the ECM that will not throw a code if they short out as they then fry that section of the ECM but it still kinda works.
Car: check
Engine: check
Transmission: check
What Gumby said. Look at the front of the driver side (left) head, if it has a similar sensor it will be for the dash indicator light.
RBob.
RBob.
Ok so this is the wire to the sensor thing
And this is on the driver side head at the front
Car: check
Engine: check
Transmission: check
Alright, we have it. As Gumby posted the picture in post #1 is the electric fan switch.
With the sender on the front of the cylinder head (last pic just above) is for the dash indicator light. I'd forgotten that the dash sender uses the slide on connector style.
RBob.
RBob.
Ok so the rear one is the fan switch, which I know works as the fan has come in and out, and the front is the sender for the dash light. Does this also send data to the gauge or is this another sensors job?
Car: check
Engine: check
Transmission: check
RBob.
It's has the gauge pack so it must be for the gauge. Thank you so much for your help with this
morrow
01-13-2024 12:29 PM
