18x8 and 18x9.6
Old 07-05-2015, 09:26 PM
Austin92's Avatar
18x8 and 18x9.6
I'm in the process of building my 1st camaro,it's a 92 rs.I'm looking at putting a set of 18x8 front and 18x9.5 rear on it..my question is what's the bs I need.the cars stock height and brakes.I do not want them out from under the wheel wells..just not my thing
Old 07-05-2015, 10:17 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
Re: 18x8 and 18x9.6
i have 18x8 front with 4.5 bs and 18x9 with 5 bs. fit perfectly..follow link in sig for pics.
Old 07-14-2015, 12:20 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: 18x8 and 18x9.6
Be smart and buy 4 wheels in 18 by 9.5. You can rotate them that way which will allow you to save money on tires. You can do 17 by 9.5 (I did, o well) but the clearance between the fronts and the outer tie rod end is very close and requires attention.
Old 07-14-2015, 12:45 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: 18x8 and 18x9.6
Agreed.
Not only rotate, but there is an important advantage of having a 275 width tire up front (compared to a 245), the extra width will give you better braking and handling - in 99% of the cases.
Old 07-14-2015, 04:51 PM
Austin92's Avatar
Re: 18x8 and 18x9.6
Trying to decide between 18 or 20 in iroc..think they are 8 in wide...nothing set in stone yet..still window shopping wheels,brakes ect
Old 07-14-2015, 11:29 PM
Skinny Neb's Avatar
Car: 1985 Trans Am
Engine: 385
Axle/Gears: 10 Bolt 4.10
Re: 18x8 and 18x9.6
Originally Posted by paul_huryk
Agreed.
There is a downside to having a 275 up front. Any bump, dip, or uneven section of the road pulls the wheel much harder driving around town if the roads are subpar. It can make the car a handful to drive somewhere as simple as your daily commute to work. That's part of the reason why I took the 275s off the front and put 225s on (the other reason was to save a some money and combined weight from wheel and tire.)
Old 07-15-2015, 09:52 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: 18x8 and 18x9.6
If that's your own personal experience I won't argue it, but my personal experience has not been that way. My car is lowered an inch or so and I only have rubbing of the wheel to the well when the steering wheel is fully turned. You should be able to set toe in 3/32" and that alone usually helps a grey deal with wandering and darting. A few members have 18x10.5 up front. I'm sure Paul can tell us what the weight difference of the wheels are from 8" wide to 9.5" wide.
Old 07-15-2015, 01:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: 18x8 and 18x9.6
I would argue as well. I ran 295's up front for quite a while and had no problems with the cars tracking or pulling/wandering on the road. 275 will be fine and i will also agree with the others here, use 4 identicle wheels and tires so you can rotate them.
Old 07-15-2015, 02:04 PM
Skinny Neb's Avatar
Car: 1985 Trans Am
Engine: 385
Re: 18x8 and 18x9.6
I've never had my car on the alignment rack because I can't get it onto the one at work, it may be clear the hell out of line for all I know. When I put wider tires on the front of my foxbody it did the same thing, even after I aligned it.
If the general experience from the majority of others is different from mine, disregard what I said.
Old 07-15-2015, 03:55 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: 18x8 and 18x9.6
Park on a flat slab and you can easily set toe with a ruler or micrometer, a thin string or fishing line and some patience and careful measurements. Mine drives straight. Camber gauges are pretty inexpensive too.
Old 07-15-2015, 04:26 PM
paul_huryk's Avatar
Re: 18x8 and 18x9.6
Typical wheel is about 1.5 to 1.75lb difference moving from an 8" wheel to a 9.5" one. Tires could be another 1 to 3lbs - depending on brand and style.
Having a 225/275 stagger is going to be a handful in turns - major mechanical understeer. I would never suggest trading that for less "wandering" to anyone.
Old 07-15-2015, 06:56 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: 18x8 and 18x9.6
18's are about at big as you want to go on a thirdgen. 20 will look a little "donk".
I strongly urge you to consider any advice from Paul. But I will suggest this, if the car will be used for drag and you can be responsible in corners so you don't go sliding into a guard rail or ditch, then the 225/275 staggered will work. The narrow front will reduce roll resistance and the of course the 275 rears will give you more traction, but the staggered 225/275 set up will hurt your cornering.
Old 07-15-2015, 08:56 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: 18x8 and 18x9.6
I don't have a problem with 275's in the front.
Before the extensive restoration began, I drove it rain or shine on terrible PA roads.
Only problem with the 275's is they aren't big enough.... planning to stuff larger tires on all 4 corners.
justins920
Wheels and Tires
03-30-2007 11:55 AM
Automotion
Exterior Parts for Sale
10-24-2006 01:03 PM
lilbowilson
04-06-2006 12:22 PM
Quick Reply: 18x8 and 18x9.6
