Zo6 rim question
Old Jul 14, 2015 | 07:20 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Zo6 rim question
I'm sure this has been asked a thousand times but I have read pages worth and can't get a 100% straight forward answer.
I'm buying some Zo6 rims but can't decide on what width to get. I want 18s on all 4 corners. I have the 2 inch spacer up front and the 4th Gen reared. What width is good without rubbing and also what is the biggest tire I can fit? I appreciate the help guys
Old Jul 14, 2015 | 11:20 PM
Skinny Neb's Avatar
Car: 1985 Trans Am
Engine: 385
Axle/Gears: 10 Bolt 4.10
Re: Zo6 rim question
To my knowledge you can't buy Z06 wheels smaller than a 9.5" width. With that width you can fit a 315 on them.
As far as rubbing, when I had C6 wheels on my car with 275/35/18s all around, it had a slight rub on the fender liner at full lock. As did a friend's car with the same setup.
Old Jul 15, 2015 | 11:13 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Ok thanks man. Anyone else ? Just need to know what tire size to buy ?
Old Jul 16, 2015 | 11:32 AM
rce2win's Avatar
Car: 1988 IROC-Z
Engine: 355ci SBC, Holley carb
Transmission: 5 speed manual
Axle/Gears: 4th gen Z28
Are you planning to keep all 4 tires the same size or will you be running wider rubber in the back? If all 4 are the same size, then your fronts will be the determining factor. I have the stock C5 Z06 17/18 combo for my IROC project.
Front: 17 x 9.5 Tire size: P265/40ZR-17
Rear: 18 x 10.5 Tire size: P295/35ZR-18
Old Jul 16, 2015 | 01:41 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Not sure. I got my rims last night they are 18x9 there not a zo6 rim but same offset.
If I can fit bigger in the back I very well mite
Old Jul 16, 2015 | 01:43 PM
rce2win's Avatar
Car: 1988 IROC-Z
Judging by this thread, you should be fine fitting the 18x9's all the way around.
https://www.thirdgen.org/forums/whee...s-all-4-a.html
Old Jul 16, 2015 | 01:49 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I know I can fit the rims I'm just wandering what's the biggest tire you can fit without it rubbing
Old Jul 16, 2015 | 03:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
275/35/18 all 4
Old Jul 16, 2015 | 04:13 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Do you have any pictures?
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Djmathis123
Sep 29, 2015 01:36 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
