Scored some NOS Ronal R15's
I posted an update on my Formula 350 thread in "Auto Detailing and Appearance", but thought this may be some helpful info for anyone considering getting these or if you already have them.
These are NOS wheels from the 2nd run in 2002. Came in original boxes with accessories and paperwork.
The spacer provided was more generic than the one that is offered by Hawks and others, Also it is 8mm instead of 1/4 inch. I got some hubcentric rings off ebay seperately. With a little machining, they fit on the spacer, to make it fit snug against the wheel hub. Longer lug nuts were used (came with the rims) on the fronts.
I am running BFG Sport Comp 2's, 275/40/17's. The car was driven after install, and the tie rods do not rub. Nothing suspension wise interfers. The wheel can be turned fully both ways and do not contact the fender wells.
My Formula is stock, non 1LE brakes on front, stock suspension.
Engine: 4++,350 & 305 CIs
Re: Scored some NOS Ronal R15's
Is that anti-seize on your studs?
I think so. Whats the problem? Torqued them to 85 lbs-on the Ronal sheet that came with it,
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Some FAT 5 Bars. I like them fatties. Would you mind posting some side pictures as well? Maybe even some of the wheel fully locked left or right, give us a nice stance ;P ;P
Clean and simple, the way I like it. Good taste, great score.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You didn't get the spacers that Ronal sold with the wheels, just an FYI. I also bought a second set in the run in 2002 and I got the real/correct spacers. As far as I know Hawks does not provide the real/correct spacer with their replacement wheels either. I offered my real spacer for design but they wanted to keep it for "design", some BS, and I wasn't going to let them keep/destroy it
Car: 92 Firebird
Engine: 4.8 LR4
I will keep an eye out for them, but essentially they are flat spacers, but they had a machined ring in the center that went into the centering ring space, so the spacer would stay centered in the wheel perfectly, and then the green centering ring would mount inside the spacer. I seem to remember them only being 5 hole too, but I could be wrong.
I just went down and looked at my Ronals, the spacers are not with the wheels. I have so much stuff I may have lost them in the house, or I may have lent them to a friend. I don't need the spacers since I have brakes with a hat, so they are essentially my spacers.
The spaces shipped with the ronal wheels are the original ones I revived from Ronal when I bought the wheels. The wheels are from the first run that Ronal did after SLP stopped selling them. Interesting point. I tried to buy the wheels from SLP back in the mid 90s when they were selling them from there parts catalog (red window color). Unfortunately SLP had a warehouse fire and all of there R15 wheel inventory was destroyed.
At this point, as long as the spacers I have work out (which they seem to so far), I am happy. I found this picture on the internet-is this what your spacer looked like?
Car: 92 Firebird
Engine: 4.8 LR4
For some reason I can't get the picture to open, but the thumb is too small to figure out.
The problem with those spacers is that it won't keep the wheel hub-centric as intended, unless the centering ring goes through that spacer too.
Location: *member since 1999, I think - just can't remember my old name, and the big site crash...*
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
COTM Editor
Received 1,856 Likes
Car: '89 Firebird
Engine: 7.0L
85 lb-ft is correct for 12 mm stud used on the years of vehicles that had the R15 wheels.
Lubricating wheels studs is a big no-no.
85 lb-ft was on the original Ronal sheet that came with the rims. I never lubricated the studs. Was like that when I bought the car in 2013. I will remove the wheels and try and wipe it off before spring driving season. Thanks for the heads up.😃
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
not a bunch of fake rivets and bs like you see on stuff today
