3.5L V6RSR begins
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
3.5L V6RSR begins
A final test fit of the bolt-ons to check fitments and to verfify color coding (what other parts I want ceramic coated silver) before everything get torn down for the build.
This is going to be a fun project. I love the looks of this little motor.
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
3.5L V6RSR? What engine is this? That looks like your custom 2.8 plenum.
Car: 89 Firebird
Can you get a pic of the under side of your engine and a side view?
I got to keep that oil in it's place.
I was going to put a windage tray and bafels in my pan, but like allways I don't have an engine to model it to.
Car: '87 Cam RS V6
Engine: Top Secret
It is starting life as a '94 Camaro 3.4 60*V6, but that is changing internally completely.
Transmission: Th700R4
Can't wait to see what it will do... Plenum is interesting... Got any info post already about it?
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
I think I must have searched for the wrong thing. Only bad thing about search, you have to use the same words as someone else. Did they use plenum or intake?...that sort of thing!
The reason you may not find anything is because that he posted it under his old name, AGood2.8.
Here is the thread. https://www.thirdgen.org/techbb2/sho...hreadid=201972
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
i was wondering if dean was still around, hes the only other person that got the headers from pf&e, sweet engine man good luck, id like to see how the intake works, maybe you can produce some for us
I believe it was posted under "custom plenium" instead of "custom plenum"... that makes the search a little harder.
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Car: '87 Cam RS V6
Engine: Top Secret
These headers are beautiful. It is actually the first chance I have had to fit them on a motor and I have owned them for just over a year now- Great work Greg (PF&E).
Agood2.8/ Afrikingoodtime
yeah im the other one that bought a pair.....they still have the stainless finish on them though becuse i dont want them to stick out...im going for the stealth look i have to say so far ive had no problems with them and they give a nice hiss sound when i accelerate and im sure they helped my dyno numbers a bunch.
still curious though if your ever gonna market that intake or just keep it for yourself lol
Car: '87 Cam RS V6
Engine: Top Secret
Originally posted by Jerriko 3.4
Just out of curiousity, what does the RSR stand for?
Pre headers:
Max Power = 121.5 @ rear wheels (+20%) = 145.8hp @ the fly wheel
Max Torque = 208.2 @ rear wheels (+20%) = 249.84ft-lbs @ the fly wheel
After headers:
Max Power = 125.9 @ rear wheels (+20%) = 151.08hp @ the fly wheel
Max Torque = 203.1 @ rear wheels (+20%) = 243.72ft-lbs @ the fly wheel
(Up by 4hp, but down by 5.1ftlbs TQ!)
Once the cut out was opened:
Max Power = 134.1 @ rear wheels (+20%) = 160.92hp @ the fly wheel
Max Torque = 207.4 @ rear wheels (+20%) = 248.88ft-lbs @ the fly wheel
I got 8.2 additional HP and got back 4.3ft-lbs TQ.
But there is all kind of issues when the car is not tuned properly, so its hard to really say. If we turbo it like planned, it will be just right though.
I would love to hear what other dyno pulls have produced!
Originally posted by vsixtoy
Its mine own label to my car and motor. Kindof like how GM dubs the ZZ4 and the 350Ramjet and the LS1, etc etc.... My version of a 60*V6 that I think will become well known through these boards. History of modifications to the rest of my car I think shows I mean business when I speak of doing something. It just takes time in life to takle all the projects I face. My house is always first. My custom brake project has been a year in creating and playing the waiting game for the custom machined parts to show up at my doorstep before I go to the next phase. That is 1 full day away from being finished and installed. One side is 100% complete and the other is about 80% together. Have to paint and do some minor fitting drilling and safty wiring then its ready for install over the Xmas holiday. Those are 13x1.25 rotors, lightweight alum hubs, and 6 piston radial mount calipers all under a 16" IROC rim.
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
I got the first set he produced. In stainless as well, no ceramic. Sporting the prototype y-pipe as well. No EGR on mine! Good quality stuff! Could not have asked for better looking professional quality headers! My only issue is that I think they might be a bit small for the engine (3.4L). The dyno numbers did not produce a jump like expected on the 3.4...
Pre headers:
After headers:
Pre headers:
After headers:
Car: '87 Cam RS V6
Engine: Top Secret
... headers! My only issue is that I think they might be a bit small for the engine (3.4L). The dyno numbers did not produce a jump like expected on the 3.4...
Car: '87 Cam RS V6
Engine: Top Secret
Originally posted by FbodTrek
Can't wait to see the final results. I'll still be here in years to come, that's gonna be one crazy little motor
Edit: You might notice the wall of the garage in the background that is prepped and ready for me to "tile" as soon as I finish the complete remodel of the room above the garage and can finish drywalling the garage ceiling. I do much more than you guys know- all by myself. Ked85 (Karl) has witness in person what I am doing to this house- he is in the trade himself and does remodels. He about sh*t when he saw my "tiled" waterheater closet
PS- I am relaxing today- every once in a while the body needs a rest.
Dean, you bring up a good point. I could not believe the difference a measly 7 psi, on a SMALL turbo made. If the intake side is that restricted, then yes - the intake/heads combo should be quite a difference! (going FWD 3100 Gen III heads + custom intake )
Car: 89 Iroc
Engine: lb9
and i for one can't wait to see how its turns out.
I can tell you right off the bat that its not the headers. You need to free up the entire intake air path all the way to the valves. You are outflowing fine, just not inflowing. Larger intake valves, decreased bends on the head intake ports, and a larger intake profile on the cam and valvetrain will show the results you need. This is where these motors hurt- turbo boost proves this.
Going to port the heads further. Had alot of people on the Feiro boards say not to take those fins out of the heads. It would mess up the air flow. So I cleaned them up and slicked them. Now we are thinking about making them thinner like a shark fin. See what that does. Also going to mill the heads. Get some flat valves. Get a multiangle valve job (have never done this) and get roller rockers. Then need even stiffer springs...
Then got to work on the larger TB. Darn contact I had is gone. He was working with some guy in Finland. If it had worked occording to plan I would have had the TB last March!. Wish I had the Finland guys info!
Then we will see how the headers do with the cut out. I already know thatnks to the cut out that the darn exhaust sys is too restrictive. Going to go with a 3in cat back sys from someone! Then i will just have to piece in the section to the y-pipe.
Then I'm thinking turbo!
I dynoed my car six weeks ago. Naturally aspirated I got 149 hp and 190 ft/lbs at the rear wheels. When sprayed with a 100 shot, it got 150 hp and 191 ft/lbs at the rear wheels. In case your wondering, the clutch was slipping pretty bad. On the nitrous run, the engine sounded like I revved it in neutral. The clutch was a spec 3 stage 3.
Though I wonder...mines an auto, yours a stick...what is the drive train loss on a stick.
What do stick guys multiply to get the flywheel numbers?
Autos have a 20% drivetrain loss. I know sticks are less.
Would be interesting to compare our dyno numbers that way!
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
a auto trans is suppose to multiply torque right??? You lose HP turining it but it makes that into torque to still move your butt???
Ah, not quite. Long story about how slippage of the tq convertor = more torque, but more heat transfered into the auto tranny. It'll build more torque, up to the stall point.
Car: '87 Cam RS V6
Engine: Top Secret
Redriaf, We do not have the displacement of air coming out of the motor to push it through 3" tubing all the way to the back of the car. You think you have troubles now with the 2 1/2", the 3" will bottle neck the gasses even more when they cool down and slow down. The smaller diameter keeps them hot and keeps them traveling to the rear of the car with better flow. This is why your cutout workd better also. The gases were able to escape out the exhaust sooner and avoid the bottleneck in length. We really need a shorter length catback setup with these samll displacement motors and 2 1/2" dia tubing is the perfect size. It the length that has to be shortened.
This is the very reason why I come out of the muffler with dual 1.75" pipes and not the 2 or 2 1/2" duals everyone else with V6's arte doing.
Car: '87 Cam RS V6
Engine: Top Secret
Cj,
In trying to find better solutions for these cars (I have designed many different suspension componant ideas for them already) I have even pondered with the idea of trying to tie the exhaust tubing into the use of subframe connectors. Noise, expansion, and heat are problems though.
Dean
Dean
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I read somewhere on my old s10 board, that having a muffler thats in 1, and out 2 loses power?
I had debated on if I have to redo my exhaust, try this. Would look a tad funky having one pipe hanging down, but if it works, it works. In side on passenger, on left side it would just dump down and slightly towards the rear.
Or you could just leave the duals and block one off. But I do like Dean's idea of having two smaller outs.
The reason I'm debating the exhaust increase is due to what some of the 4th gen 3.4 guys have done.
*We got stock 2.25 inch pipe. (3.1 & 2.8)
*3.4s came stock with 2.5 (what I found on Camaroz28)
*The 3.4 (stock) guys upgrade to the cast off 2.75 exhaust SLP was selling from the cars they upgraded. Thay have great results so I hear. They say the car is stronger.
*So why would a modified 3.4 (to the extent I'm talking with the bore & hone increase) not warent something larger?
That was the logic I was going with. That and the dyno shop was convinced it was the pipe size as well.
Car: '87 Cam RS V6
Engine: Top Secret
Definately go up to 2 1/2" from the stock 2 1/4". This will give a gain. But you will start to lose again going bigger than 2 1/2". That is the optimum size for these motors. Header pipe diameters prove this. Optimum power is produced from y-pipe merge into 2 1/2" collector. Hooker & hedman duals merge into a 2 1/2" pipe on each side then dump. If you hook those together with a y-pipe they fall on their face. They are designed to run open header. The optimum y-pipe primaries are 2" not 2 1/2". the optimun header primaries is 1 5/8"x 26" long for open race headers and a 2 1/2 collector for under 4000k, but 2 1/4" for over 4000k operation. Shorter and a smaller should be used on a closed exhaust system to maintain the heat needed to push the exhaust out the muffler further away. These are GM test results.
Just understand this one main point. As exhaust gases cool, they slow down. The larger the pipe diameter, the faster they will cool. The smaller the pipe diameter, the more restriction of flow. You need to have the rpoper balance between the two. 2 1/2" is the correct size. Don't listen to what some guys on some board are claiming there 2.75" exhaust did unless they have dyno sheets to prove it- I would bet that its in the head, the car will "sound" faster with a deeper tone.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I was just thinking the other night about NASCAR exhaust. How they do to ground clearance make them wide and thin square pipes to fit. as oval or round would drag.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yep the fake duals is more restrictive then real.
Once I fixed all the leaks in my system my car felt weaker in the higher R band. I should of just left it alone but I got exhaust leak fix happy. and then I could not deal with the performance hit.
it really sucked all the life out of the upper band.
That when I ripped out the stock fake dual and went with the single out.
Engine: 3.4L 207 V6
Its nuts how the cam I got is actually a HP cam, not a troque cam, but its torquey in the 3.4....though we had Reed profile it out for a 2.8. Its so odd that you have 16hp on me and I have 17 on you in TQ.
Vsixtoy, I don't mean to highjack your thread, I am just answering comments.
I dunno, my 3.1L really likes the mandrel bent 3" I've got on it
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
But you got a turbo D. you have plenty of BP. Actualy your might like it if you ran a progressive pipe. Keep getting bigger n bigger as much as you can. End up with a 5in fart can.
You running a muffler?
Definately go up to 2 1/2" from the stock 2 1/4". This will give a gain. But you will start to lose again going bigger than 2 1/2"...
Also, have you thought about insulating the exhaust to retain heat?
Car: 91 Camaro
i have to argue against the 3" being too big. sorry. i am running the old hooker headers, dual 2 1/4s into a single 3". the 3" run from just behind the tranny to the 80 series flowmaster in the back. i have run the car at the track with the full exhaust, just the 3" catback (no muffler), and i have run just open headers. my times basically didn't change with any of these setups. i know it seems wierd but that's what i've experienced. also, i am wanting to ceramic coat my entire exhaust system for insulation purposes.
dean, on your motor, that pic looks awesome! i, too, can't wait to see what you end up with!
Any guesses on what to expect from your motor Dean? Or is it just a wait until the install-and-see? I can't quantify the performance of that thing myself, but I can qualitatively say that it's going to rip some serious pavement (especially compared to my car!).
Car: '87 Cam RS V6
Engine: Top Secret
It will be N/A and I am shooting for 240-250 FWHP. remember, I also am running an electric WP and a superlight bottom-end rotation assembly with 6" rods.
The internal of the block will look as pretty as this -
https://www.thirdgen.org/techbb2/sho...hreadid=268722
yeah i disagree on the 3" being to big as well...im running PF&E headers into 2 1/4 tubing into a y pipe 3 inch to the muffler and then 2 1/4 back out of the muffler....seems to run very well, looks as though my tq numbers jumped a lot from it
Engine: 3.4L 207 V6
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
There is a good article somewhere [gotta find it]
"You can build a quiet exhaust system that performs almost like open headers."
http://www.pontiacstreetperformance....p/exhaust.html
Engine: 3.4L 207 V6
