Super Ram With Strut Brace
Old Apr 10, 2005 | 08:41 PM
purplebird's Avatar
Car: 1992 firdbird formula
Engine: 5.7 tpi
will the kenny brown triangle strut brace bar fit a 1992 formula with the super ram installed? If not what about the 2 point from jegs or summit
Old Apr 10, 2005 | 09:10 PM
Z RATED IROC's Avatar
Car: 89 Camaro
As long as you don't have Polly engine mounts it should fit.
If you do have them, Anything will rub.
I used to run a Superram and had allot of trouble because had the mounts. They lift the engine about 1 to 1.5 inches.
Old Apr 10, 2005 | 10:47 PM
Kandied91z's Avatar
yeah i have alot of clearance with my hotchkis and the superram however i had new rubber gm mounts. i've seen the troubles polly brings with the height.
Old Apr 12, 2005 | 05:03 PM
vladicore's Avatar
Car: 67 camaro ( project )
Engine: 6.7 408 n a snail
Transmission: 4l80 - stalled
Axle/Gears: 3.25 - narrowd tci kit 9 inch
so the hotchkis stb will clear the accel superram?
Old Apr 13, 2005 | 12:28 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
YEA
Old Apr 13, 2005 | 09:07 AM
vladicore's Avatar
sweet thanks a million, i been puttin of buying one for awile now not knowing if it would fit!
Old Apr 13, 2005 | 10:05 AM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
The Hotchkiss fit on mine as well. I did add some 1/8th inch aluminum spacers under the base plates just for a little extra clearance, but it fits fine.
Old Apr 27, 2005 | 12:35 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I don't understand why the poly mounts raise the engine more than new rubber ones would. I can understand that if you go from old beat rubber ones to poly you whould see a height change but why do they sit higher than rubber? Anyone have pic's of the poly mounts? I'm about to get one or the other and need to know soon. Thanks
Old Apr 30, 2005 | 06:13 PM
laegion's Avatar
Car: 84 Trans Am Ws6
Engine: 305 LG4 "H.O."
Transmission: wc t-5
they don't, i have energy suspension poly engine mounts and they are exactly the same as the stock ones except that they are made of polyurathane.
Old May 3, 2005 | 02:18 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I put es polly mounts on mine and the kenny brown stb rubs on my stock tip intake now so i had to pull it off. Sorry dont have any pics.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
