View Poll Results: which are the best heads for a 305?
Vortec L31s
20.00%
World S/R Torquer 305s
20.00%
L98 vette heads
60.00%
Bowties
0%
Multiple Choice Poll. Voters: 15. You may not vote on this poll
Old Apr 2, 2002 | 05:31 PM
DABE's Avatar
what are the best heads...for a 305
Dabe
Old Apr 2, 2002 | 05:39 PM
SoCo80p's Avatar
the 305 isnt a real deep breathing engine so spending alot of heads really isnt needed
Old Apr 2, 2002 | 05:54 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
true, but gains can be had. I ported my L69 heads and am very happy. with the cam i have, it pulls hard to 6200 rpms. i say L98 if you don't want L69 cheapos.
Old Apr 3, 2002 | 08:45 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
the L30 heads work better on 305's than the L31 although i'd still go for the L98.
Old Apr 13, 2002 | 10:55 PM
iroc22's Avatar
Car Craft built a 330hp 305 with untouched L31 heads. Super Chevy found 35 ponies when they swapped from L98 aluminum heads to L31 Vortecs.
Old Apr 13, 2002 | 11:01 PM
DABE's Avatar
do you like your world heads??....
Old Apr 13, 2002 | 11:12 PM
iroc22's Avatar
Love them, plus unported they flow better on the intake side than the L98 aluminums
Old Apr 13, 2002 | 11:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There aren't many guys out there who have had two of those choices on a 305 - I certainly have not. I also can't say how much improvement they made, because I did so many other things (like all of the mods in the sig) at the same time. But, I like the way the package came together (just need to get the tranny to behave for that 2-3 shift...).
Old Apr 14, 2002 | 07:25 AM
DABE's Avatar
what do you mean you cant get her to behave??....welp....in my 305....the car is in ALL stock trim...i can chirp them pretty good going in to second...and remember..i have a 3 speed auto...and thru 1st...if i punch it....smoke starts a flooding....welp i think im going to get the heads bare...and get some nice stainless steel valves and take my roller tips and springs over to the new heads....does it sound like a good idea?..
thanks
DABE
Old Apr 14, 2002 | 08:13 AM
Jester's Avatar
You forgot the option in the poll that says "don't waste your money on heads for a 305, it's not worth it"
Old Apr 14, 2002 | 12:35 PM
iroc22's Avatar
Yeah thats what the guy with the 69 Chevelle 350 told me right before I waxed his ***.
Old Apr 14, 2002 | 04:35 PM
DM91RS's Avatar
Car: 91 RS
IMHO if you "have" to get heads for a 305 make sure that they will work on a 350 when the 305 or you have had enough.
Old Apr 14, 2002 | 05:29 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
lol
Old Oct 21, 2005 | 11:52 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
what are prices on all these heads right now,
and more importantly: what casting number(s) are L31 heads ?
and what years did these come out and were these used ?
enquiring mind needs to know asap
oh and what is the L30 engine exactly ?
thanks
Old Oct 21, 2005 | 12:14 PM
V6camaroman's Avatar
i would dare tell you to stay away from the 64cc or larger heads. mainly because you lose presious compression. and to regain it you have to get a higher comp piston or a thinner head gasket and it just begins a bunch of math equations. now there are 3 good head stock head options for a 305. the 416's, 081's and 601's. stock for stock i think that the 416 outflows the others by a very little. but the 081's and 416's are very common and respond well to mods for example mw66nova has a set on his 305 that went 13.0. now the 601's you cannot forget about they are a great head too. they came on a lot fo van and truck motors through the 80's. i dont know a lot about these heads but the good thing about the 601's is they flow excellent and even better than the 416's with a nice port job. and they also have a lower cc i beleive its like 52cc compared to the 416 and 081 58cc. so you can gain a little comp there. i myslef have a set of nicely done 416's on my 85 305 tpi motor and im expecting mid to high 13's out of it. but they have a lot of work done to them
Old Oct 21, 2005 | 01:09 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
where can i get some 601's or 416's?
do they work on a 350?
Old Oct 21, 2005 | 01:33 PM
well any junk yard or pick a part sould have them. as long as they have some older 80's 305's laying around your good. the 416 casting heads came on all 80 to 86 car motors and the 601's came on all 80 to 86 truck motor. dont quote me on that but i beleive those are the years. if anyone has any insite to add please do
Old Oct 21, 2005 | 10:07 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
how would the world torquer 305's work on 350? I've kinda been eyeing them. I don't want vortecs
Old Oct 21, 2005 | 10:13 PM
i have untouched 416's on my 350 and they do good, not great, but good. If I would've had the money I would've had bigger valves put in. I calculated my compression to 10.47:1
Old Oct 21, 2005 | 10:49 PM
cameojon's Avatar
Car: 1984 Camaro 10.48 e.t.
Engine: 500+HP 383 stroker
Transmission: 2/3 speed depends on the track
you guys are forgeting, talk to a couple of engin builders in you area that build 305s for sprint cars they make 480 hp out of stock 601s and stock rods and crank
Old Oct 22, 2005 | 01:22 AM
83 Crossfire TA's Avatar
Any specs on the 350 block?
What does "they do good, not great, but good," mean?
I'm thinking of dropping the 416's off of my '83 crossfire engine onto the '92 350, LO5 truck engine I have...
Old Oct 22, 2005 | 08:51 AM
[QUOTE]Originally posted by 83 Crossfire TA
[/Qs
stock block and pistons, comp 270 h-10 cam, It'll scoot once it's going but I seem to lost some torque. I haven't driven it much waiting on my exhaust. Hopefully next weekend.
Old Nov 10, 2005 | 02:31 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
I have a set of 416 heads for sale if you are still interested.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
