Holley Stealth Ram braided fuel lines/adapters/ adj. regulator
Old 12-29-2008, 05:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Selling my custom made fuel lines for Holley Stealth Ram.
Stainless Braided -6AN line with Russel -6AN fuel fittings. Also including PureChoice Motorsports hardline adapters so you can bolt these lines to your factory hardlines. Adapter fittings attach to factory hardline 14/16mm fittings.
Lines are as pictured here. they route to the rear of the fuel rails. One line is slightly longer to reach the far side rail.
Lines with adapter fittings- 75 shipped.
Holley Stealth Ram adjustable fuel pressure regulator. Works great. 25 shipped
Located in Pittsburgh PA
Old 12-29-2008, 06:12 PM
lthrneck's Avatar
Car: 89 Iroc
Axle/Gears: 3.70 9bolt
Re: Holley Stealth Ram braided fuel lines/adapters/ adj. regulator
I will take them Orr. You have a PM
Old 12-31-2008, 04:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Sold-- fuel lines
Regulator still here
Old 03-16-2009, 09:33 PM
Want a title? Post!
IROCSCOTT's Avatar
Car: 90irocz
Sold-- fuel lines
Been a while but Do you still have the reg?
Old 03-17-2009, 07:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah still do actually
Old 03-17-2009, 08:01 PM
Want a title? Post!
IROCSCOTT's Avatar
Car: 90irocz
I may not need it after all. Talked to Holley again today. They are supposed to be sending me a replacement for the bad one that came with my Stealth Ram.
Old 04-29-2009, 08:13 PM
theboilermaker's Avatar
Car: 87 camaro sc
Engine: 357 w/ cc qjet
Transmission: 700 r4
Did you ever get rid of the regulator? Also, how do the fuel lines connect to it?
Old 04-29-2009, 09:12 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
No longer parting with the regulator. But the line attached to a 90 degree fitting on the regulator
Frozer!!!
01-19-2024 04:55 PM
9192camaro
16
02-03-2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
08-25-2015 09:14 AM
Dialed_In
08-20-2015 01:45 PM
L98GTA87
08-11-2015 06:55 PM
Quick Reply: Holley Stealth Ram braided fuel lines/adapters/ adj. regulator
