[NC] SD TPI harnesses (2)
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Ive got too much wiring here and need to make space
Up for grabs are two 90-92 TPI harnesses
Both have been repaired, tested and tagged, ready to install. There are no broken clips, hack issues or melted places. I dont have any good 730 ECMs or chips currently
$175 shipped each
Direct fit for 90-92 305/350/700R4/4L60 engines. Also plugs in directly for V6 to TPI swaps. TBI swaps require mods. Will repin to older 3rd gens for an additional fee
Also have an 82-83 CFI harness/ECM and 88 TPI corvette harness. Probably wont get any interest on here but you never know
Trades considered for LSx parts, cut up 3rd gen harnesses, tools, 85-92 firebird console lid, raw steel stock (angle, round, flat, sheet etc), 10 bolt posi w/ 3.42 or lower gearing (82-02)
Pic of one
$175 shipped each
Pic of one
Car: 84 SC Camaro (92 Tribute)
Engine: V6
Transmission: M5
Re: SD TPI harnesses (2)
I don't guess this would work on an '86 Iroc with a 305tpi 700r4? I could ship you my harness that needs help after I swapped them out if it helps with the price. Would my stock computer work? Thanks
Car: 92 Firebird
I can repin it to 86 for $50
No the stock 86 ECM wont work, you'll need a 90-92 730 ECM and chip to match your 305/700R4
Car: 92 Firebird
It can be repinned for a carb for an extra $50. You'll have to mount a separate fuseblock because carb car wont have the INJ1/2 fuses in place. Fuseblock is included. Fuel pump wire will have to be connected
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
I would like one would you be interested in my old one its all there just has brokin clips on some plugs.
Car: 92 camaro 92 s10 99 caddy 91 4x4
Engine: 305 tbi for now
Transmission: 700 r4
Axle/Gears: 3.73 limited slip
Still have the harnesses? Wondering how much for 730 ecm with vats programmed out of it? I have 92 rs tbi wanting to convert to tpi. Have tpi setup except harness and ecm. Wanted something to just plug in. I have two wiring harnesses, first one is original 1987 iroc z 305tpi harness, kind of pulled apart, the other is painless universal harness for 1986- 1988 tpi. Was installed in s-10 pick up, was only time used. Also have two ecms for the mass airflow system. Thanks.
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
wow I wish I seen this before I overpaid for garbage from somewhere else... next time I'll know!
IBrockZ
08-20-2015 12:20 PM
Sanjay
08-12-2015 03:41 PM
