Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
What plug to use in firewall when passing gauge wires through it???
Old Jun 25, 2002 | 10:31 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
What kind of plug, seal or gromet is used to plug a hole needed to pass new gauge wires through the firewall?
I would like the best suggestions here. Not worried about saving money, but having a wet floor.
Damn I hate interior leaks.
Thanks.
Old Jun 26, 2002 | 12:11 AM
Morley's Avatar
Don't drill new holes. On the driver side there should be a firewall wire block and it should have a few unused holes in it. Just run a pick or scribe through the empty holes you want to use and then feed your wires through there. It makes for a professional looking install and doesn't add any holes in the firewall.
~M~
Old Jun 26, 2002 | 07:02 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Great idea. Thanks.
I am also going to run a boost gauge which is mechanical. So it will probably have a vacuum line running into the inside of the car. Will probably have to drill for this one, eh???
Old Jun 26, 2002 | 08:40 PM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
when i did my mechanical water temp guage you have to run about a 3/8" nut through the firewall and i just used a circle drillin gbit to go through the metal, painted the bare metal that was exposed and inserted a rubber grommet i bought at the local auto parts store...
Old Jun 27, 2002 | 12:02 AM
Morley's Avatar
Originally posted by mypontiac
Great idea. Thanks.
Nope, that nylon vacuum line is very small (like 1/8") and should fit through the wire holes in the bulkhead connector too.
~M~
Old Jun 28, 2002 | 07:58 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Cool! :lala:
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86IROC112
Aug 17, 2015 07:57 PM
Jk_Under
Aug 17, 2015 03:08 PM
