Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
View Poll Results: WHICH INTAKE?
Weiland Stealth
50.00%
Edelbrock Performer RPM
40.00%
Edelbrick Victor Jr
5.00%
2 carb Chevy Street tunnel Ram (What the heck right?!?!)
5.00%
Voters: 20. You may not vote on this poll
Which intake?
Old Sep 3, 2002 | 12:14 AM
86IROC350NY's Avatar
Which intake?
I have heard from many posts that the Weiland stealth is the thing to get. But will it be good for my application. Take a look at the sig and assume I put in all the parts in my trunk.
THANKS!!!
--Dan
Old Sep 4, 2002 | 01:47 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I have it. I don't see why it's not a good choice for you.
It's a good choice for almost any street/strip type of car.
Idle-6800 rpm powerband or so.
Old Sep 4, 2002 | 02:49 PM
THANKS!!
I talked yo you about this lready...kinda. Because of you i am getting Dart Iron Eagle heads with guideplates set for .600 lift (1.43 springs). I am gonna get a set of Pro Mag Roller Rockers, a Comp XE cam (284) and lifter kit and crane cams heat treated chromoly pushrods.
All of this timed by my PJ gear drive and Fed by the stealth. I just hope I win the heads off ebay.
Thanks for your help!
--Dan
Old Sep 4, 2002 | 08:41 PM
Car: 99 Formula
Axle/Gears: 342
Dang, a 284XE, is this your daily driver?
Old Sep 5, 2002 | 05:38 AM
yeah
its my daily, but i plan on selling it when i graduate next may. I know i will need a vac reserve tank also.
--Dan
Old Sep 5, 2002 | 08:05 AM
ronterry's Avatar
Car: '94 Corvette
You might be able to get away without using a vacuum reservoir. I'm at 6300 (7" at idle) feet with a XE284/Victor Jr., and only get a hard pedal when at idle. So backing up is a little ruff.
Starting & idle is acualy good, if you have your carb tuned.
XE284 for the street ??? You might have more fun with a 222 duration than a 240/246 zooming around town.
Ron
Old Sep 12, 2002 | 08:19 PM
N8Miller's Avatar
86iroc350ny: you and my cousin have almost the exact same set up. he added the RPM intake and is very happy with it.
can you give me some tips on tuning that SA 670 carb-----we cant quite get it just right.
That cam is a mighty mihgty cam. it will pull like a hooker from like 2500 on. the XE274 might be just a bit better for the street. but hey, its your car.
Old Sep 13, 2002 | 07:50 AM
Car: 99 Formula
Axle/Gears: 342
I hope you have gears and a stall to back that cam up.
Old Sep 13, 2002 | 08:38 AM
I got gears
My gears are really short in my T-5, and the rear is 3.73.
Don't need a stall converter in a manual
Old Sep 13, 2002 | 11:27 AM
Car: 99 Formula
Axle/Gears: 342
Re: I got gears
Old Sep 13, 2002 | 11:29 AM
What's wrong? I am also getting 4.10s for the rear that will be put in before the cam goes in.
Old Sep 13, 2002 | 12:24 PM
Car: 99 Formula
Axle/Gears: 342
Nothing is wrong, I was just putting because you have a stick and I asked about a TC.
Old Sep 13, 2002 | 01:46 PM
oh
I am kinda new and I was thinking...manuals have stalls? Holy **** I know nothing.
Thanks for clearing that up mark!
Old Sep 27, 2002 | 01:24 AM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
I hope you have at least 10.00 to 1 compression. That cam thumps hard and you will have to get used to the valve train noise that comes with that cam. Just about everyone that runs that XE 284 or bigger XE has lots of lifter noise.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
