do pulleys and e-fans really work?
Car: 84 camaro z28 with F41 option ex-cop car
Engine: Carbed 305 v8
hey guys i have a 99 f150 with a 4.6 v8 pulleys and a e-fan really woke that baby up i wa wondering how these mods will do on a carbed 305 auto 84 camaro?
Car: 99 Formula
Axle/Gears: 342
Not much.
Vader once told me that a clutch fan is the way to go.
An E fan will just put more strain on the electrical system.
Pullies, well that may cause charging problems. I would go with other mods first.
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I think Electric Fans and Underdrive Pulleys will help more on higher-revving engines equipped with manual trans more than a 305 driving an auto trans.
Your 4.6 litre Ford is a higher-revving engine by design compared to the 305 so I don't think you could expect to see the same results doing the same mods to the 305.
Auto trans tend to keep the revs down so the fan wouldn't rob as much torque off the crank as compared to a 5-speed.
Car: 1989 Iroc Z L98
Originally posted by Mark A Shields
Not much.
Not much.
also, electric fans are a fun toy to have in the pits at the drags to cool your motor off between passes
Not true at all......... Electric fans from the factory are efficent and reasonably quiet. The fan only comes on at a preset temp. so the only time there is a "drag" on the electrical system is when it comes on. I've never had a problem with mine. All Camaros LG4/LO3's (I think) came with the single fan set up after 1986.
As for underdrive pulleys, that debate is more of a choice, some say they work others say it doesn't.
I stay away from underdrive pulleys honestly. i considered them, but underdriving your charging or cooling system usually isnt the best idea in the world.
i would stay away from the underdrive pulleys, they're not really worth that much power, and the really screw up your charging system. camaros are notorious for having small amps, you dont need to compound the problem. the power can be found elsewhere. timing...headers...etc
evilstuie
Jan 9, 2020 08:29 PM
Navy8125
Aug 22, 2015 07:13 PM
mcquigg
Aug 13, 2015 02:26 PM
Street Lethal
Aug 12, 2015 11:33 AM
db057
Aug 11, 2015 10:11 PM
