Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
problem with Megashifter?
Old Apr 24, 2003 | 06:09 PM
rxbxfx0220's Avatar
I've recently purchased a B&M Megashifter (actually from someone on this site) I have no complaints, but shifting through park, reverse and neutral is HARD AS HELL!!!!... I was just wondering if this is a common problem that someone else may have experienced, or mines just screwed up somehow. Any input appreciated... Thanks, Steve.
Old Apr 24, 2003 | 07:12 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
They are pretty stiff when they're new. You get used to it, and they do loosen up some over time.
Old Apr 24, 2003 | 07:13 PM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
It is claimed as a TUFF shifter from what I've heard. Mine is the same way I dont think yours is bad. Just my opinion.
Old Apr 24, 2003 | 08:18 PM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
question/ megashifter
When i try to ratchet it from 1st to 2nd it goes straight to 3rd or to neutral. Is it supposed to do this and what am I missing????
My linkage is not well adjusted but I did not think it had anything to do with it. Thanks!
Old Apr 24, 2003 | 10:35 PM
SpeedCat86's Avatar
88Spinner: it sounds like something is out of whack in there. You should have to ratchet back from drive to first, in order to rachet back up to drive.
IIRC, there's a pin and a couple of leaf springs that connect the shifter handle to the cable mechanism. One of these is most likely loose or missing. Take off the shifter boot, and watch the mechanism while you shift through the gears. You will probably notice something out of whack, or see something that should be there but isn't. Hard to say without seeing it.
Old Apr 25, 2003 | 03:47 AM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
thanks I will look soon and get back to this post.
Old Apr 25, 2003 | 05:26 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
P,R,N is a bitch, period, but i could care less how quickly i can shift between them, as long as 1,2,3 are there
Old Apr 25, 2003 | 07:23 AM
Dr G's Avatar
Steve:- They are all quite stiff but double check the adjustment of the cable anyway. Check that there are absolutely no kinks at all.
Gordon.
Old Apr 25, 2003 | 07:36 AM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
Excuse me I am new to the shifter. When you say ratchet it do I put it in first and push it to second WITHOUT touching the t-handle anymore? Also when I put it in 1st should it be able to go into neutral? When I put it in first and push it up nothing stops it from going to 3rd and neutral. Everyone mentions how they throw the shifter and when I "throw" this one it wants to go into neutral. Thanks for any clarification.
Old Apr 25, 2003 | 07:39 AM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
I know I pretty much asked the same thing but I need some more clarification with "how to operate it." Just double checking myself.
Old Apr 25, 2003 | 01:54 PM
SpeedCat86's Avatar
With the shifter is in Drive, pull back on the handle. It should move back one 'notch' and stop. The PRNDL window should indicate 3rd gear (or 2nd on a 3-speed)
Release the handle and pull back again. You should now be in 2nd gear.
To go from Drive to 1st, you will need to pull back on the shifter three times.
Shifting from 1st to Drive is exatly the same. Each time you push the stick forward, it will move one gear and only one gear.
The way the shifter is designed, you can 'rachet' between any of the positions from 1st to Neutral (N-D-3-2-1), but to access Reverse and Park, you haave to be in Drive, and pull up on the lockout handle, the little one on the front of the shifter.
If your shifter can go from 1st to Neutral in one move, like you say, it's broken.
Old Apr 25, 2003 | 03:47 PM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
Thank you for the great explanation! Yhea, I think it is time to tear it apart or buy a new one. Another thing that sucks is it didnt come with a window just the shifter and the boot. Thanks again!
Old Apr 25, 2003 | 06:38 PM
MIDNITERIDER's Avatar
Car: 1988 Formula 350
Transmission: 700R
Axle/Gears: 9 Bolt...3:27
The spring like finger that goes into each of the teeth type gears may be out of adjustment. Just loosen the screw and watch to make sure the V of the finger goes into each gear and when you have the right spot; tigten the hold down screw.
Old Apr 26, 2003 | 12:53 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I think his is what he's talking about.
Old Apr 26, 2003 | 12:54 PM
mine was off a bit and I adjusted it. but then again what he's talking about may be something internal ....toward the bottom of the shifter where all the gears meet...sorry if Im wrong...
Old Apr 26, 2003 | 01:38 PM
Transmission: 700R
If his shift linkage at the tranny was out of wack; when you say tried to go to first or park--you cant. This would indicate that the cable at the tranny connection needs adjustment. I had the same problem as above until I adjusted the leaf spring as shown in the pics above.
Old Apr 27, 2003 | 11:13 AM
rxbxfx0220's Avatar
Yeah, i have to get around to taking a look at that spring finger thing, it can be slid up or down, right? I don't know for sure, I haven't loosened the screw yet, but that's what it looked like. I Don't think there is a kink in the cable because I spent about 20 minutes with my dad just making sure everything was ok down below, and the only problem is with park and reverse. Maybe it does just need time to "break in". I'll have a look-see at that spring when I get a chance. Thanks guys. This seems to be quite a common thing, not just this but problems with these shiftrs in general. Hmm, oh well.
Old Apr 30, 2003 | 02:23 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Sorry this is a little off topic, but can you guy's tell me what I can do to get the TC to lock-up. I was told I need some kind of relay from radioshack for this shifter. If so, how do you hook it up?? (bought it used)
Old Apr 30, 2003 | 02:50 PM
heres what you need.
Old Apr 30, 2003 | 02:52 PM
heres the diagram for it.
Old May 1, 2003 | 06:46 AM
Car: 91Z
Thank's Wish, that was exactly what I was looking for.:hail:
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
