MSD Ignition
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
MSD Ignition
I have always heard people talk about MSD Ignition boxes.
However, I am unclear as to what they actually do and whether you will be able to tell the difference with/without one installed (i.e. are they worth the money)?
I have an 89 Formula 350 TPI (if this info helps).
Thank you.
Thank you.
Basically they increase the power of the spark and how many time it actually sparks. You most likely won't be able to notice any more power, but you may notice better gas mileage and maybe a smoother idle and faster start up.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
(I have always heard people talk about MSD Ignition boxes.
However, I am unclear as to what they actually do and whether you will be able to tell the difference with/without one installed (i.e. are they worth the money[B])
Yes they are worth the money... They improve rpm range, starting and idle, throttle response and top end power. Yes you will notice a difference once it is installed. The majority of stock ignitons are inductive ignitions. In an inductive ignition, the coil must store and step up the voltage to maximum strength in between each firing. At higher rpm since there is less time to charge the coil to full capacity, the voltage falls short of reaching maximum energy which results in a loss of power or top end miss. MSD produces full power multiple sparks for each firing of a plug. The number of multiple sparks that occur decreases as rpm increases. Above 3300 rpm there is simply not enough time to fire the spark plug more than once so there is only one powerful spark. Is it worth it? Absolutely! Dont know why anyone would tell you not to bother, its no big difference...Its a marked difference. They are easy to install. Easy to understand and MSD even has a hassle free tech line.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by 92TRANSAMWS6
My local Autozone carries them. You can them from SUMMIT and most anyone else.
autozone charges too much... id order from summit or some other hipo shop that sells enough of them that they sell them cheaply.
off the top of my head, i think the price diff between autozone and summit for a 6AL was like 40 or 60 bucks....
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
take a look at the crane boxes. they even come with a coil for free. from what i hear they are very similar. i myself went with a holley annihilator because it was being clearanced out by jegs for the new line from holley. its a shame i havent been able to start the motor yet though.
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
hey spartyon...you can't start the motor with the new ignition? or you don't have time to work on the ignition?
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
Where is everyone mounting their box at? I looked for a decent place on an IROC last weekend and we ended up fabricating a plate to mount it over the top of the charcoal canister. Just couldn't find enough room to mount it anywhere under the hood so we had to create room.
Car: 1986 camaro
Engine: 383 sbc
yeah.....there doesn't seem to be that much room in a thrid gen engine compartment..maybe in the interior, like nascar. any guys out there with pics of your installs?
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I put a MSD 6AL box on my 406. I had a really bad miss above 5800rpms, it felt like the valve springs were floating. After I put the box on the miss was gone and will go to 6300 smoothly and revs a little better. Stock igintion systems were not intended to push 500hp@5800rpms.
It starts quicker too, actually my carb 406 starts faster than my 89 T/A with FI. I can hit the key and the 406 will start, the TBI car takes longer and in the morning I have to try twice sometimes for it to kick over.
On a bone stock/mild setup it may not be as noticeable. I dunno.
Later
Later
Car: 1987 Camaro IROC Z-28
mounted mine on the interior side of the firewall...but my car has been stripped and I can actually reach the firewall easily on my car :-p
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
