Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Engine Stand ?
Old Nov 12, 2003 | 07:04 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Engine Stand ?
Hi guys, kinda new to the board. I'm going to be starting my rebuild on my 86 Iroc fairly soon. I'm ditching the 305 for a new 350. My question is what kind of engine stands do you guys use to build on? I've seen one in Summit racing that is pretty nice, $63, and you can rotate the motor while its on there. Is that worth it? I should probably get something to put the engine on before getting it. Any suggestions? Thanks
Old Nov 12, 2003 | 10:07 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i got a new one from the local "farm king" for 35 bucks on sale. it rotates to. try a local store like that or farm and fleet. sometimes you find a good deal.
Old Nov 12, 2003 | 02:14 PM
Jubba's Avatar
I got one from Autozone for $40, it has 4 3" casters and rotates. My mechanic friend uses this kind. He said he even hung a big block on his.
Old Nov 12, 2003 | 03:03 PM
demonchild's Avatar
if it holds an engine and rotates it dont matter. i got mine from harbor freight for 40 bucks. this isnt one of those things to spend money on. put the money in what the engine stand holds.
Old Nov 12, 2003 | 09:34 PM
EvilCartman's Avatar
Car: '82 Z28
Gotta put some money into it otherwise the heavy bit on front will be on the ground
Old Nov 13, 2003 | 06:29 AM
Car: 1986 Iroc
Engine: Afr 408
Thanks guys, I'm going to try the local autozone and I believe there is a Farm and Fleet around here also. I really don't want anything fancy, don't need no $150 stand, but I got to have something to build on. I started off by looking in Summit, but they want $62. On a side note. I'm think about a set of fast burn heads and Summit wants like $80 more than scoggin-dickey. Is that because Scoggin-dickey is Gm dealer or whatever, or does summit marks stuff up? Anybody find similar price differences?
Old Nov 13, 2003 | 02:44 PM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
SD buys from GMPP, so they get a better price. this in turn gives you a better price.
Old Nov 13, 2003 | 03:09 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
4 leg rotating stand at Advance Auto for $34.99
Old Nov 15, 2003 | 10:27 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i got one from (i think) advance auto for like 35 bucks a couple years ago. it can also rotate the engine. it was cheap, but works fine.
-brian
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
anesthes
Mar 10, 2016 10:35 PM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
