Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Need Chip!
Old Nov 4, 2001 | 11:53 AM
VaneGTA's Avatar
Need Chip!
Ok here is the deal. I've got what was a 91 Trans Am convertible with a 305 TPI which of course has SD. Now I just put in a 350 TPI from an 89 GTA I bought wrecked since the motor in the Vert was locked up.
I kept the SD system and the computer still has the chip for the 305 in it. Am I better off just going to GM and buying an SD chip for a 350 or should I just spend extra on something aftermarket?
Old Nov 4, 2001 | 12:21 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If the 89 engine you put in is stock, the stock 91 GM 350 chip should work just fine.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 4, 2001 | 01:14 PM
VaneGTA's Avatar
Yeah all I added was SLP 1 3/4 headers, high flow cat and hooker aerochamber catback. I just need something to make the car run right because it is running HORRIBLE right now. Thanks for the reply.
Old Nov 5, 2001 | 08:07 PM
Pete92TA's Avatar
I have a performance resource chip for my 92bird works good. Not that pricey either. Just a thought. http://www.performanceresource.com/
http://sites.netscape.net/bulldogfrazier/homepage
http://www.fracoinc.com/
Keep your ride shinning with pride
Old Nov 6, 2001 | 10:22 AM
camaro6spd's Avatar
how hard are the PR chips to install? How do they install?
1987 Black 305 TPI 5spd IROC, G92, 9-bolt 3.45, Lowered, Cat-back, Air Foil, Sub Frames, Huge sways.
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
Old Nov 6, 2001 | 08:06 PM
FstBrd6point3's Avatar
they are relatively easy to install. . . just under the passenger side dash compartment and remove the 3 bolts thaqt hold the lower plastic part on (at leats that's how many were left intact on mine) and the computer is up inside the panel near the edge. . U can't miss it. It is held in with 2 bolts on the bottoma dn then just slips right out. If it looks the same as mine on my 350 there should be a small yellow box on the side, unplug those wires so you have some room to move it. After that find the side with the little screw down plate and take it off. Once it is off, there are 2 little clips that hold the ship in, push them out I think to remove them, put the new one in, clip it down, put the plate and wires back on, put the dash back together and you are ready to roll. It took me about 10 minutes.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
