Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Hotchkis vs. Spohn
Old 09-12-2000, 02:19 AM
82z
82z's Avatar
Hotchkis vs. Spohn
I want to add new lca's and a panhard rod to my car. Basicly I am looking at the Spohn units and the Hotchkis'. Which do you guys think would be better. They seem to be pretty comparable.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi
Old 09-12-2000, 08:24 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Honestly LCA's and Panhard bars are going to be pretty much the same. Only differences would be if they're adjustable. The biggest plus side would be that Steve Spohn supports our site and our hobby.
Old 09-12-2000, 10:07 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I have Spohns adjustable LCA's,panhardbar and torque arm and I'm very happy with it.The quality is second to none and the prices are fair.I would rather buy from someone I know than a big company anyway.I have used Hotckins stuff on my freinds 79 camaro and it was good stuff also,but Steve's stuff is also top notch.
Old 09-12-2000, 04:25 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I'd go with SSPE. Steve's parts are VERY good quality and don't cost as much as Hotchkis.
I'm running SSPE adjustable poly/moly LCAs, adjustable Panhard bar, LCA brackets and adjustable torque arm. I should have my SSPE SFCs soon.
Old 09-13-2000, 07:21 AM
Scott 87 IROC-Z's Avatar
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
I have Spohn's LCA and PH bar and they are built very well. Another place to check out is BMR at www.bmrfabrication.com
87 IROC-Z 305 TPI
MSD 6AL & Blaster II Coil, Richmond 3.73, K&N Filters, TPIS Airfoil, TPIS AFPR, Custom Cold Air, KYB Shocks & Struts, Ported Plenum Runners and Manifold, Comp. Eng Subframe Connectors, SLP Headers, Borla 3", Hi-flo cat, TH700-R4 with TCI Pro Super Kit and 2100 rpm stall converter
www.acsu.buffalo.edu/~ermer
***** FOR SALE *****
Old 09-13-2000, 08:35 AM
blak92!'s Avatar
n/m
[This message has been edited by blak92! (edited September 13, 2000).]
Old 09-13-2000, 08:36 AM
blak92!'s Avatar
Hotchkis is wayyy overpriced and overrated. You can get the lakewood boxed LCA for $80 from jegs or summit, which are very similiar at less then half the cost of the hotchkis items.
For the ultimate in traction (but very obnoxious to drive with every day, I only swap them for the track) is the Herb Adams sperical bearing LCA for $140.
Old 09-13-2000, 10:42 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Spohn has that too. I got mine with a Heim on 1 end and a poly on the other fro my LCA's and my panhard bar. Really good stuff.
James
If the women don't find you handsome they should at least find you handy. Red Green
Old 09-17-2000, 06:16 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I like Spohns stuff and his prices. His parts look more solidly built then Hotchkis's and at a cheaper price. But i do like the Hotchkis springs tho.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/15/00)
There can be only one!!
Ed1LE
09-30-2018 09:14 AM
darwinprice
17
10-11-2015 11:51 PM
Nervous2
10-08-2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
10-08-2015 06:11 AM
84 TA NV
09-06-2015 08:02 PM
Quick Reply: Hotchkis vs. Spohn
