What do you guys think about the TPIS Mini Ram?
I know it is #1 by flow tests and all, but how hard is it to install, how well does it work all together?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Current Mods: Edelbrock TES Headers, Hooker Cat-Back System, Performance Resource Chip, 160* Thermostat, Accel 8.8mm Ignition Wires, K&N high flow air filters, gutted air box, gutted MAF sensor, Throttle Body Coolant By-Pass, Homemade Ram-Air, Falken ZIEX Z-Rated Tires.
1/4 mile times without chip:
Best ET: 15.7 @ 89MPH
Best Corrected ET: 14.5 @ 96MPH
L98 TPI 350 (5.7L)
Its awesome! Guido is putting together a tech article on his installation of it. Look for it here soon.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
From what I hear they are pudry good for top end HP =) The catch is tho that you have to buy all the fuel rails and stuff from TPIS.
Kat
90 RS TBI 305 A4
My so called mods
one offically slow car
The **** poor member of the Infamous North East Crew
Kat
90 RS TBI 305 A4
My so called mods
1 Post
Car: 2000 Trans Am
I think it is awesome! TRAX and I are putting together a long technical article about it that we will be posting in the tech section. We both have it and can offer good suggestions on what to do, what to use with it that will work well.
-86 IROC
Vortech stuffed EFI 406 in progress
-86 IROC
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Yea,
Stay tuned. You won't be disappointed.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Tim
Thanks guys, I will keep my eyes on the tech section.
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES Headers, Hooker Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.3 @ 97mph
L98 TPI 350 (5.7L)
Car: 1972 Corvette
I am replacing my Super Ram with a Mini Ram. I had to take the heads off to rebuild them and didn't feel like F**king with that damn super ram anymore, so I bought a mini ram.
http://firehawk.cmcmfg.com/~east/ste...s/DSC00001.JPG
I am not changing anything else on the motor, not even the cam. The dyno results in my sig are with the super ram. In the coming months, I will dyno it again with the mini ram and once-and-for-all end the SR Vs. MR debate. This is on a naturally aspirated street driven 350.
Stay Tuned
'91 Z28 Blue/Silver ZZ4/ZF6
335.9 rwhp 374.9 rwtorque
Stay Tuned
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Steve...Be sure and post the whole Rpm range if you can. IM interested to see how the midrange changes. From the dyno tests ive seen you should pickup around 10-15 horses on the top with the 219 cam. The lowend should stay about the same with a loss in the midrange. They where all N/A motors though.
Car: 1972 Corvette
I have the LPE 219/219 cam with 1.6rr for .560/.560 lift.
I realize that the mini ram would do better with more duration, but I don't have the money to buy another cam.
My performance thirdgen book tested a 350 corvette engine and printed the results stock vs mini-ram. Book says stock 350 with 1/7/8 dyno heads. This is short version they list 2000rpm start 5250stop in 250rpm intervals. I can more numbers if needed but this should be good.
Stock:Peak hp=242.3at4250rpm
2000rpm=120.6hp,2500=155.5,4000=238.5,
4500=241.3,5250=216.1
Miniram:Peak hp=311.5at5250
2000=116.0,2500=149.8,4000=259.0,4500=288.3,
5250=311.5
Sorry for the long post.
http://sites.netscape.net/bulldogfrazier/homepage
http://www.fracoinc.com/
Keep your ride shinning with pride
5250=311.5
I ran faster and quicker with ALL my combos with the Mini-Ram over my SuperRam. Blown and N/A versions of 355 and 383...
1989 Formula, 383", DFI, Mini-Ram, S-Trim Vortech, blah, blah...
Best ET: 10.796 @ 125.8 mph
TURBO 406 PROJECT STARTED!!!
Other expensive hobby: assault weapons/shooting sports
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association
http://www.mfba.org
Employed at:
Hahn Racecraft
http://www.mfba.org
here are the graph for both the MR and SR on my 383. Nothing else was changed. I was running the 85 ECM. they dont give much scan dat but take the mode fairly well. I was running the same custum chip for both. The sr is bare to install each time. The first time for the miniram was a little extra work . now that its setup it can be removed in a half hour try that with a superram. As for the 1/4. My times were so very close. I ran 12.0 with both setups. O verall I would not trade off the miniram. I love it.
Superram dyno.
miniram dyno-Sorry for the cutoff. But you can still see the overall figures.
85 vette,383,miniram,ZF6,4.10's..best ET 11.81@117.00 60' 1.65
http://geocities.com/bowtie8
[This message has been edited by BOWTYE8 (edited September 17, 2000).]
Superram dyno.
for emission inspection it will fail like he said no EGR. but for operating my setup passed with the installation of a cat .
Dennis
Dennis
Sanjay
08-12-2015 03:41 PM
