Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Full Length Headers?
Old Apr 4, 2005 | 05:05 AM
Silver_Panther's Avatar
Car: 1982 Z28 & 1987 Z28
Engine: Carbed 400ci & TPI 305ci
Transmission: TH-200C & TH-700R4
Alright I've currently got a 400 small block in my '82 Z28 Camaro and I'm lookin for a good set of full length headers with 3" collectors.. What would u guys suggest? And those who have them already how well do they fit?
Old Apr 4, 2005 | 08:08 PM
Shagwell's Avatar
Car: projects.......
If you do a search, you'll get like 10,000 posts. You only have two choices. Hooker or Headman. They're the only companys that make long tubes(LT's) for the 3rdgen. If you have a stock style(sideways mounted) manual trans, then you only have one choice, Hooker. The Hooker's are 1 3/4 primary, the Headman's are 1 5/8. Unless you're high compression, decent rpm(about6k) and aftermarket heads,cam,etc, the Headmans will do everything you'll ever need. If you're the above(sweeeettt power) then the bigger primary's are nice.
later, justin
Old Apr 5, 2005 | 12:13 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
I just bought a set of Hedman Hedders (the long tubes) for my firebird, havnt run the car at all (engine and tranny are still waiting to go in), but the headers look great! I'm sure they'll be more than enough for what my engines gonna be making....and the price cant be beat, i sold a set of used edelbrock headers for more than it costs to buy these hedmans!
Old Apr 5, 2005 | 04:44 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
my 305 has had hedman longtubes for about 2 years now and it runs consisten 13.70's and has potential to run 13.3's or faster. my father also runs the hedmans and is running 11.7/6's.
Old Apr 6, 2005 | 08:30 PM
Thanks for the input.. My main concern was how well they fit.. I had a set of supposedly "summit" full lengths for 82-92 camaro given to me.. But the passenger side doesn't clear the A arm properly. So i'm lookin for a new set and may have a chance to pick up a set of hooker super comps for a really good price..
Old Apr 6, 2005 | 10:38 PM
mw66nova's Avatar
Engine: 7.0L
sounds like the hedmans. they fit fine after you take a sawzall to the a-arm perch. you'll also have to dent one of the primaries *slightly* to clear the k-member on the drivers side.
Old Apr 7, 2005 | 06:41 AM
Any pics of this process available? Would like to find a set of full lengths that don't require extensive mods..
Old Apr 7, 2005 | 11:03 AM
mw66nova's Avatar
Engine: 7.0L
it's not extensive at all, all you have to do is just grind or cut about an inch or two off the corner of one of the perches. it's really easy. i have thrown these things in two cars now in under an hour. you'll have to make a small dimple in one of the primaries also on the driver's side. you cannot go wrong with these headers, especially for the money. you need get under the hood and try to put these things in if you really want to know what needs to be modified.
Old Apr 10, 2005 | 03:02 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Does anyone know if you have to make adjustments for the Hookers?
Old Apr 10, 2005 | 08:49 AM
mean57's Avatar
Car: 87 gta
there is a step by step install on th hookers
Old Apr 10, 2005 | 12:58 PM
I asked a simple question. How about a simple yes or no.
Old Apr 10, 2005 | 01:19 PM
mean57's Avatar
Car: 87 gta
yes there are a couple fitment issues.
the thread i was refering to would benifit you greatly
it's not hard to install them but can take some time.
if you look in the exhaust forum i believe there is a sticky
on it. if you read it first you can make the adjustments before trying to fit them save you lots of time.
sorry for the short prev answer.
Old Apr 10, 2005 | 01:33 PM
It's not a problem. Thanks for telling me about the sticky. I am not ready for any installs yet. I was just curious. I will go with hooker because I need the 1 3/4. It will benefit me more than 1 5/8.
Old Apr 10, 2005 | 02:23 PM
84-350berlineta's Avatar
Car: 84' Camaro Berlinetta
Engine: 383
Transmission: TH350
Check out this thread for ALL the info (mods and pics) on installing hooker super comp headers.
https://www.thirdgen.org/techbb2/sho...hreadid=148210
Old Apr 11, 2005 | 01:12 AM
Thanks.. Actually just picked up a set of super comps for $150 friday night.. They only had a few passes on them and the car was sold to this guy.. And this guy runs a big block so he had no use for them... dam was I happy.. Looks like these aren't gonna be nearly as pain in the *** as the summit's..
Old Apr 11, 2005 | 11:46 AM
Chrome's Avatar
Car: 92' RS Camaro
Awesome deal!
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Jun 7, 2016 09:47 PM
92projectcamaro
Jan 18, 2016 08:00 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
