Auto Meter 12201 Triple pillar pod Fitment problem!
#51
1 Post
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Re: Auto Meter 12201 Triple pillar pod Fitment problem!
Don't remember exactly--probably left it as long as possible-- but where it is not starting to flare out --where it is straight so it matches anywhere U slide it up or down.
#52
Car: 1989 IROC-Z
Engine: 5.7
Transmission: 700R-4
Axle/Gears: 9-Bolt Borg-Warner 2.77
I will post a picture when I am done. Thanks again.
#53
1 Post
Car: 1989 IROC Z-28
U will pleased if U do sanitary work.
Regardless if it is where the plastic was flared, or where U cut it where it is straight, there always be an edge to look at. People that look at mine have no idea that's not the way it's supposed to be!
If U take the time (only took me a few minutes) to sand the edge where it tapers thinner to the pillar underneath--a finished edge so to speak--it will look as good or better than the original.
#54
Car: 1989 IROC-Z
Engine: 5.7
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
It took only 5 minutes and I plan to feather the edge like you described. I will take some pictures when I am done.
Thanks again, it just some ballz to go ahead and cut it!!
#56
Car: 1989 IROC-Z
Engine: 5.7
Ok, they aren't hooked up yet, but they are fitted and mounted....
#58
Car: 1989 IROC-Z
Engine: 5.7
I couldn't help but throw a couple of pics of the car in......
![nod](https://www.thirdgen.org/forums/images/smilies/nod.gif)
#60
Car: 1989 IROC-Z
Engine: 5.7
Yeah, and the wires are run down under the dash. I just have to drill a hole in the firewall and then terminate the ends. I have already figured out I need an adapter for the Schrader valve for the fuel pressure. I am trying to figure out what I need now and get it ordered. I also need to look closely at where I am going to hook up the vacuum/boost gauge.
Any thoughts?
Any thoughts?
#61
1 Post
Car: 1989 IROC Z-28
You're asking the wrong person!!!
Post the qusetionon the general engine (or whatever the appropiate board is --if there is one for your type induction system) tech board.
#62
Car: 1989 IROC-Z
Engine: 5.7
I know where to get the vacuum/boost now by asking on the power adder board.
As for the fuel pressure, I know with TPI, I will get it off the Schrader valve. I thought maybe you had ran a fuel pressure gauge in your pod and knew what fittings I needed. Sorry.
#63
Car: 1989 IROC-Z
Engine: 5.7
Oops.... didn't mean to post it twice.....
Anyway, thanks for the help with the pod, I tried to share that with others too.
#64
1 Post
Car: 1989 IROC Z-28
Naw, I'm ols school and races round round cars for years. I ran water temp, oil temp, and tranny temp.
#65
Car: 1989 IROC-Z
Engine: 5.7
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
I have mostly been a drag racer and have always liked the f-body, probably because parts were plentiful and cheap!
#66
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
nice fitment job, thanks for sharing.
#67
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
this is for the 12201 pillers (hard top) are the same fitment issues exsistant in the 12203 pillers (T-top)?
#68
got my triple pod over the weekend and I cannot believe how badly it fits ![EEK!](https://www.thirdgen.org/forums/images/smilies/eek.gif)
I do not see how 'quality control' let this garbage out of the building with their name on it.
It looks like I will be modifing mine in the same fashion as pinky93 has shown above. Thanks for sharing the info and pics.
#69
Car: 87 TA
well, the quality controls job is really to make sure the product isn't flawed in any visible way. make sure there are no plastic burs, warps, cracks, things like that...but they really should check the fitment of their products.
#70
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
db057
08-11-2015 10:11 PM
