Anyone tried new Thumpr Cam?
Car: 84z
Engine: 305 HO carb
Axle/Gears: stock
has anyone tried the new Thumpr cam by comp cams... i like the way they have a rough idle...in the summit catalog its part # CCA-12-600-8...would this cam work well with a 305?
1 Post
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Re: Anyone tried new Thumpr Cam?
I think it might be a little too big for a 305 depending on which one you want. I was thinking about the Big ***** thumpr for my 406.
Car: '82 Camaro Z28
Engine: 383
Axle/Gears: 3.73 with powetrax
I thought about using one in my 383 but decided to go with a new voodoo retrofit roller. Not because I dont think the thumpr wouldnt be good but for my setup I felt the voodoo was better suited. Yeah those retrofit lifters are expensive but less drag = more power and longer life. Your not gonna flatten a lobe on a roller cam as quick as a flat tappet. It all comes down to the old saying speed costs money......
Car: 85 Trans Am
Engine: LG4
By the looks of the numbers, I think it would do well in a 305 with a nice set of well ported heads, good intake and exhaust. Stock heads would need to be modified to accept that high of a lift, though. I wouldn't consider going above (or possibly even near) .450 lift without having the valve guides machined down.
....Or new heads. Hah.
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I call BS on all of this, go with the Voodoo, or the Extreme energies series cams, buying a cam for the sound is nonsense; these 2 are the newest grinds of flat tapets and if you break them in correctly they should last for 150,000 miles. Skip the retrofit, skip the fancy sound and go for a real performance oriented camshaft. You won't regret it later on down the road. P.S. Use Rotella T if you have a flat tappet cam they depend on it.
