Summit Full Length Headers?
Car: Camaro
Engine: Carbed L98
Transmission: TH350
You would be better off buying the Hedman or Hooker version. I have the Hedmans and they work good. I did have to clearance the LCA on the drivers side, but that is normal.
Oh yeah, the Hedman are 1 5/8's primary. I think flowtech is 1 1/2.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Originally posted by GOY
Do those even fit....
Basically anything longtube is better than the shorties I have now.
Basically anything longtube is better than the shorties I have now. If you car is lowered, you might not need to go the LT headers. They will be close to the ground.
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Hedman it will probably be then. I head the hooker's collector is REALLY low.
Did you have to replace your starter with a mini starter with the Hedmans?
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Basically anything longtube is better than the shorties I have now. Why do you think that? Short tube headers are proven to provide more of a top end boost compared to long tubes.
Look at some of the recent articles in Popular Hot Rodding, I think. They are interviewing a guy that does a lot of custom header / exhaust work.
Results on tube length, collector length, tri y 's etc... are pretty interesting.
Everything I've read, seen, and experienced is that short tube headers are only good at the top end,and provide minimal benefits at lower RPM's, where Long tubes provide benefits across the board. Maybe you misread that article? Maybe they said short tubes were only beneficial at higher RPM's, not that they were MORE beneficial than long tubes at higher RPM's?
ambainb
Apr 25, 2016 09:21 PM
tom1985
Apr 19, 2016 07:55 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
IrocZ'85
Aug 17, 2015 06:24 PM
