HEADLIGHTS NOT WORKING
So I go to turn on my headlights after I got out of work and they don't turn on. The Parking lights work. This is not the first time this has happened. Sometimes I'll go out and they wont turn on. Ill go out and try a few minutes later or even the next morning and everything is working fine and dandy. What the hell could this be? I had a new Light switch/**** installed on the dash and that seemed to fix the problem ( at least for a couple months), but now the problem has resurfaced. Does anybody ever heard of this or even experienced it? It's really frustrating because I don't know what's causing it and I never know when they will not work.
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
The bushings inside the motors are crap and break apart over the years. TDS sells a delux rebuild kit for about $20bux and it works great, I would recomend rebuilding the motors with the kit.
Car: 89 GTA
Engine: 350 TPI L98
Originally Posted by 88 Ram Air TA
Check your connections. There is probably a loose wire somewhere.
It has to be something with the wires or their connections. Joined: Nov 2002
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I think your in the wrong category, but yes check your wireing & also there is a relay in the fuse box for the lamps.If the relay is tripping on there may be a short somewhere.After the relay cools off it will reset & your lamps will work again.
Car: 1991 Camaro RS
Engine: 305 v8 TBI
Re: HEADLIGHTS NOT WORKING
I have a 1991 RS as well. I just dropped my steering column to get to some bolts on the fire wall, and when I put everything back together, my headlights weren't working. Any ideas? I suck at troubleshooting electrical components, so any ideas would be great.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Make sure everything is plugged in all the way and correctly for starters....
Car: 1991 Camaro RS
Engine: 305 v8 TBI
Will do. All of my other exterior/interior lights/gauge lights are working, so I'm not sure why the heck they cut out on me. I was hoping it was the relay overheating or something, but this morning, they still weren't working.
I'll check it again, and if it's still hooked up properly, then I guess it's time to bond with some wiring diagrams...
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Drop the column again and check the wires that run the length under neath the column bracket. You may have pinched one under the bracket. I did that once and drove myself crazy blowing wiper fuses before I figured it out.
Car: 1991 Camaro RS
Engine: 305 v8 TBI
You mean the wires that run from left to right underneath the column?
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
