SLP cold air kit
SLP cold air kit
Does anyone have the SLP cold air setup? If so is it worth the 200 something dollars? Any pics? And will the one filter work on a 3.1L Camaro?
Yes i have one, and no it's not worth the cost. I bought one because i put a supercharger in my Iroc and wanted to put the air cleaner on the passenger side, and the battery on the driver side. If youre a little creative you can adapt a firebird system from a junker for a whole lot less. Get a k&n filter though.
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I agree with odin65. I have one also and the rubber ducting is basically off a later TPI Firebird with an aluminum plate riveted in the middle(to direct airflow I assume). Not worth the 200 IMO. For a cleaner install, you can just get the cold air box separately from SLP and then go to a junkyard for the ducting. You'll save way more money.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60' on "Road Hugger" radials and dead Auburn posi.
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
I bought a used cold air kit for the chicken awhile back. The kit came without instructions and the harness for moving the charcoal canister over to the driver's side. I got a copy of instructions from SLP but I never mounted the box (which pulls in air from the passenger fender in front of the wheel). I ended up using the ducting just because and then removing the '89 air can, plopping the K&N on top of the base, and installed a '90 air can lid and long bolt to hold it down.
I always thought the camaro system was superior but I don't have the numbers to back it up. There are a few examples of homemade ram-air camaro systems out there.
Another option which I don't have the parts for yet is to get an 85-86 vette air intake, lean the radiator/ac condensor way back and mount that up in there with some fabrication.
Is the system better??? Beats me but it looks a lot better than the hacked up dryer hose system I got the car with. I think my '90-'92 lid deal is better than an older can with holes cut into it.
If you want the air box, and stock firebird air ducting let me know - something could be arranged. For your 6 cyl camaro system the MAF would have to be relocated.
'89 Formula - Thunderchicken - 355 Vetteheaded TPI/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
I bought just the box and lid for about $70. It hooked up nicely to the stock duct.
92 1LE Trans Am
5.0 Liter, 5 speed
SLP Headers
Dynomax Cat-back
SLP Cold Air, Chip
SFC, Strut Tower Brace
92 1LE Trans Am
5.0 Liter, 5 speed
SLP Headers
Dynomax Cat-back
SLP Cold Air, Chip
Brinkkl2000
08-04-2018 08:29 AM
db057
08-11-2015 10:11 PM
