Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Solid roller cams on the street? Good or Bad
Old Apr 15, 2007 | 07:20 PM
jborders10's Avatar
I was wondering if some of you guys who were running solid roller cams in vehicles that are driven on the street often would share your thoughts. I was thinking of changing to roller either hydraulic or solid. I've heard that the newer solid rollers have much longer lives on the street. Wondered how some of you liked or disliked yours. Thanks for any replies.
Old Apr 16, 2007 | 08:01 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Re: Solid roller cams on the street? Good or Bad
Been running a solid for about 7 years now with no problems.
Old Apr 16, 2007 | 12:21 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
How often do you have to set valve lash?
I was thinking about going solid roller too.
Old Apr 16, 2007 | 12:41 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
anyone running a solid roller with a manual??????????????????
i've only heard people say no problem with an auto.. never seen a manual run a solid roller before.. but i'll be the first.. one day, after someone else beats me to it..
Old Apr 16, 2007 | 12:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you need to groove your lifter bore, or use lifters with a groove in it, so that oil will run down onto the roller. Otherwise it doesn't get enough oil on the roller at lower RPMs (street driving).
If you do that, you're set.
Old Apr 16, 2007 | 01:09 PM
laiky's Avatar
I think comp makes the correct lifters, wish i had gone solid with mine.
Old Apr 16, 2007 | 02:58 PM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
there is nothing wrong with a roller on the street. the only issue is how radical the cam is. the more valve spring seat pressure there is the faster the valve spring will weaken. Camshafts with lots of duration and lift will need a valve spring with alot of seat pressure. the best thing to do is call the cam company and ask them. i deal with cam motion. they only build custom cams, none of there cams are off the shelf. you call them and tell them what your doing and they will design one for you.
Old Apr 16, 2007 | 03:19 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
If you get stud girdles then you will not have to keep resetting valve lash. Best 200 bucks I ever spent.
Old Apr 16, 2007 | 04:08 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
I heard you still have to adjust valves even with stud girdles is that true?
How long has it been since you adjusted your valves?
Old Apr 17, 2007 | 08:29 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
1 or 2 times in 7 years
Old Apr 18, 2007 | 06:12 AM
sp63
Guest
Posts: n/a
so if i have a stock hyd. roller i can just get some (grooved) solid roller lifters and they will slide right in?
i plan on doing a cam swap soon and i want to ditch the hydraulic lifters...
Old Apr 19, 2007 | 12:24 PM
jborders10's Avatar
Thanks for all the input.
Old Apr 19, 2007 | 02:03 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Anyone here try using retro solid roller lifters on the street?
Old Apr 19, 2007 | 08:41 PM
strokeronthesause's Avatar
the best way to go for a roller is(if u have the budget) shaft rockers,(i use t&d) crower severe duty with HIPPO option, and good valve springs. with this setup i went 3 years shifting at 7500rpm on motor and 7200rpm on spray. i set the lash twice in that period, the only reason i did it the 2nd time was to see if i could find some et. motor was sold TODAY!!!! new combo stronger and faster!!!
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
Street Lethal
Aug 13, 2015 08:28 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
