Clutch pedal/linkage bushing
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Just some info.
For those of you, who like me, could not find the little plastic bushing that holds the hydraulic clutch push-rod to the pedal.
I found the part in a package at the auto part store, the ones with the big "HELP!" written on the top, made by Motormite. Part # 14041. comes with the clip and a few other parts, costs like 5 bux. I assume its the same clip for all the years.
Re: Clutch pedal/linkage bushing
I found the original part# for that bushing/clip in my GM parts book, and gmpartsdirect actually still has them. It's listed in their alternate catalog under the original part#, which is 14091384, and it lists for $4.17. Just thought I'd add this to the post since there's so many posts where it's broken and people can't locate a replacement.
hmmm forgot about this thread. I also got the bushing from gm. the issue i found was even though we went through the exploded diagrams of the pedal assembly and hand selected the part numbers, all the parts were wrong, the bushing fit in the pushrod, and onto the pin of the clutch pedal, but then there is a metal retaining clip that is supposed to then snap over the end of the stud and into the groove to hold things together. I found that with the plastic bushing, there is no more room on the stud for the retainer clip . Is there more than one setup? I currently have one of the bushings, cut apart to that it basically just lines the inside of the pushrod and a "E" clip holding everything together, and thats a tight fit. Its been holding up fine, but im just a little confused. Everywhere i looked i say the two pieces, yet they dont seem to work together.
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I used a brake pedal linkage retaining clip on my clutch linkage worked fine
hey pat, that setup is actually exactly what i have now, my master has the braided line, i actually think it is a 4th gen unit, and i also have the aluminum slave that i bought from nelapse while i was doing my 5 speed swap, its good stuff. My master cylinder did not come with any bushing, so that why im using the other clip.
no i didnt buy it new, i was an ebay piece, but i was is very good shape, so it probably not that old, my current bushing setup is working fine, ill just have to see how it holds up.
cross-reference this thread for info on the bushing that connects the clutch pedal and the clutch cylinder rod:
https://www.thirdgen.org/forums/tran...re-1988-a.html
Car: 1989 & 1990 RS V8 TBI
Engine: 305 5.0 L
I bought the new bushings, but does anyone by any chance know how to put them in? or atleast could give me some advice or pointers on how to do it???
If I remember correctly, if it's like the original bushing, it just snaps into the hole. Has like 3 tangs if I remember right. Hey I just found another message thread that has some really good pics of the bushing. It is how I remember it, with 3 tangs the help it snap in place in the rod. https://www.thirdgen.org/forums/tran...re-1988-a.html
Car: 1987 Z28 zz440
Engine: ZZ440
Transmission: 5spd
Axle/Gears: 4:11
the ones you get in the auto parts store package dont have the small lines sticking out that lock in the groove cut in the shaft look carefully those lines sticking out go in the groves on the shaft, can't find the things anywhere!!!!!!!!!!!
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Gm direct sells them, I just bought 3 from Autoplicity for 6.97 each
Looks like Rat's suggestion is probably your best bet. The only other options would be to see if you could possibly buy an original one in useable shape from someone here on the forums or fab up your own bushing somehow. But yeah, if I was in your position I'd probably just buy 2 or 3 new ones from GM Direct. That'd be the easiest/most painless way!
Car: 85 IrocZ
Engine: ZZ5 350 Crate. 400hp400ftlb
For all you gentlemen who are struggling with this stupid plastic bushing self-disassembling on you, it happened to me in rush hour... wow was I PISSED.
Anyhow got it towed home because the cops were there. Simple fix. Napa automatic transmission bushing kit 615-1422 Take the white bushing and cut the damn retainers off, use a mill file and file it down to fit flush in the master cyl rod end. Then buy a clip P/N 3817880 from local GM dealer and put one of these damn things on there. SCREW that plastic piece of JUNK. Fixed forever.
