Trickflow G1 versus Vortec
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Anyone have any personal experience with both the Trickflow G1 and Vortec heads? I was curious if the older G1 design would hold it's own against the Vortec heads.
1 Post
Car: 87 IROC
Re: Trickflow G1 versus Vortec
I believe the older G1's were limited to amount of valve lift you could run before you got into geometry problems, i think the area of .520", which isnt much if plan to use a roller cam. Also I remember back in the day people who bought some the first ones that came out, had issues with the valve guides wearing out, might be something to look for.
Transmission: 200R4
Your correct on the valve guide wearing. This is because the intakes need a longer pushrod to maintain geometry. I am planning to run a roller cam but a mild one. Well below .520. More in the order of .480. I have also run Vortecs but not in the same vehicle. I have run Vortecs on my third gens. And I have run the G1's in my Suburban. Not much of a comparison to go on. I was hoping someone has run both heads in similiar vehicles and what they thought.
Car: 1991 z28
Engine: l98
Vortecs+new intake=674.90
TFTW+Stock intake=1165.00
TFTW+ Avg. Aftermarket intake=1364.95
Prices from SDPC for Vortecs and intakes, vortecs have valve spring upgrade included. Performer RPM airgap used as sample. Prices for trickflow twisted wedge heads from summit racing. It all comes down to what you want. If you want to budget and get some good HP then you do the math. The TF's offer reduced weight, and improved heat dissapation, and you can run more compression with less chance of detonation.
Personally, I am on a budget and plan to use the vortec tpi setup, and a cam os some sort. If i had $$$ falling out my ***, def. an aluminum head setup. Remember now a days cast iron is still cheap. Aluminum is still going up.
Transmission: 200R4
I wish I could see some G1 flow figures. I bet they are in line with the Vortecs on the intake and flow better on the exhaust. GM heads from day one have always been just fair on the exhaust side. Factory Vortecs have proved no better. Maybe the newest Bowtie Vortecs have addressed the issue.
I am running close to 400 rwhp on factory casting vortecs up to 5800 rpm, about what most aluminum heads at any price would produce for half the price, its all about the cam selection.
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
What can did you use?
330hp_91RS
06-23-2003 11:12 PM
