Stock intake w/K&Ns vs slp cold air intake
Car: ws6
Engine: ls1
Transmission: m6
As of now I have 2 k&n's in the stock intake. Would I notice any gains switching to an slp cold air intake?
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: Stock intake w/K&Ns vs slp cold air intake
The stock Camaro system breathes air from in front of the radiator, so it's warmer than ambient but not hot like Firebirds breathe. My guess would be that you will gain no measurable power, not with your current combo listed on your website. IMHO, in current form your heads/cam are the limiting factors.
But if you step up to a serious engine package the cooler air/less restrictive SLP unit will give you more power, but right now, your air box/filter is not the bottle neck. Every time you find and eliminate the bottleneck in the system, you just find another bottleneck somewhere else!
TA
TA
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
The air that it breates from in front of the radiator is the ambient air, which will be much cooler than the air inside the engine bay. One suggestion would be to gut the stock air box and look at one of the hawks ram air setups that you put in back of the fog lights that brings more air into the system.
Car: ws6
Engine: ls1
Transmission: m6
I already gutten the air box. I think im going to get a ZZ9 cam. Im sick of bolt ons...
1992 Trans Am
05-10-2023 07:19 PM
db057
08-11-2015 10:11 PM
