Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Torque Arm Relocation
Old Dec 15, 2008 | 05:57 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Great idea!
http://www.umiperformance.com/2228?category_id=171
Old Dec 15, 2008 | 06:01 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Torque Arm Relocation
Originally Posted by BADMAN
yea i seen it, i want one!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! i wonder how good it works
Old Dec 15, 2008 | 06:33 PM
SpeedMetalT/A's Avatar
Car: 87 Trans Am
Engine: L98 350 w/carb
Transmission: TH350
I've wondered the same thing b/c I will be buying one in the spring for my TH350 swap.
Old Dec 15, 2008 | 07:16 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
no reason to buy that without replacing the torque arm instead. Get a stiffer tubular torque arm to reap the benefits
Old Dec 15, 2008 | 07:20 PM
89RS_82Z's Avatar
yea i already got a stiffer tq arm, im really thinking about getting this, the way my trans is built it shifts so solid it was tearing up rubber trans mounts, so i went poly on the trans and tq arm, now the next weak point is that tail shaft
Old Dec 15, 2008 | 07:32 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Thats pretty much what spohn makes....
Old Dec 15, 2008 | 09:38 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Thats why I just bought this
Old Dec 16, 2008 | 10:28 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Your always one step ahead of me. I was going to post this, also because spohn has a spherical mount for theirs as well. Woot Woot. Good idea but Spohn already has it..
P.S. UMI and Spohn are equally #1 to me, just Spohn makes alot more. And now in custom colors.
Old Dec 16, 2008 | 11:16 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
My problem is I have a UMI Torque Arm and a Spohn driveshaft loop on a stock crossmember. The new UMI relocation crossmember trans mounting does not look like it's going to work with my Spohn driveshaft loop. And I need to keep the loop. So I sent Ryan a e-mail asking him if he is going to make a compatiable driveshaft loop in the future. If not I will be selling the torque arm and driveshaft loop and will have to purchase the Spohn unit like krisb410 did.So be watching the classifieds!
Old Dec 16, 2008 | 11:38 AM
krisb410's Avatar
Just to clear things up, I posted the UMI unit. But I'm sure the Spohn unit is just as good. Also, UMI has always done custom colors
Old Dec 16, 2008 | 11:56 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
My bad, forgot UMI makes a identical type of torque arm and is also cheaper in price than Spohn. So looks like I may be buying one if a driveshaft loop for the new location crossmember is not a future product.
Old Dec 16, 2008 | 04:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
UMI's crossmember mount arms like kris posted are also made a bit beefier than spohns, with a better material choice for the crossmember. Im sure it weighs a little more, but its a tough piece.
Old Dec 17, 2008 | 07:59 AM
UMI Performance's Avatar
Thanks everyone
Actually just the torque arm relocation kit is different then the Spohn piece and the tunnel mounted arms we already make.
The main reason for this piece is a lot of you already have after market torque arms that mount in the factory location such as our's, Spohn ect. So instead of removing the torque arm completely and replacing it with a new torque arm and mount this item allows you to use the torque arm you already have. This item will work with the stock torque, all our torque arms and virtually any aftermarket set-up. So if you already have a good adjustable torque arm but want to mount it off the tailshaft of the transmission... this item is for you!
If I can help anymore please ask. Thanks!
Ryan
Old Dec 22, 2008 | 10:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by UMI Performance
Thanks everyone If I can help anymore please ask. Thanks!
Ryan,
A question without much merit to most: Would removing the torque arm from the tail shift reduce (or perhaps increase) noise and/or vibration? Or is there no perceptible effect at all?
JamesC
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
89newfun
Sep 16, 2015 09:28 AM
