Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Best aluminum water pump
Old Mar 7, 2010 | 09:52 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Who's got the best aluminum water pump for my l98 tpi 350? My old pump just left the building
Old Mar 7, 2010 | 10:30 AM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
Re: Best aluminum water pump
http://www.stewartcomponents.net/Mer...de=ChevyHiFlWP
Stage 2 and up are aluminum
Get your checkbook out
Old Mar 7, 2010 | 10:32 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i really like the eldebrock i put on mine back in '98
OEM quality,special oversized impeller,made in usa
Bought to replace the original with a leaking seal,
the extra flow of the eldebrock made no noticable
difference in cooling in my case,but can't hurt
Old Mar 7, 2010 | 11:42 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Not alot more then the eld.
Chevrolet Small Block - Long Stage 2 - 23123
Code:23123
Price: $168.95
Quantity in Basket: none
1987-Up Passenger Cars and Light Trucks w/Belt Drive Pumps.
CCW for serpentine belt.
Old Mar 7, 2010 | 12:34 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
What does one do when the alumi's start leaking?Will edelbrock rebuild their pumps for you?
Old Mar 7, 2010 | 12:37 PM
ls six's Avatar
Lol, buy a new one, it's a wear part.
Old Mar 7, 2010 | 12:50 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Whats lol about it.Its a $150 plus dollar aluminum pump, not a cheap rebuilt cast iron piece.
I would definately try to get it rebuilt or at leasts see if the manufacturer would take it as a core!Only a shmuck would just throw it out.
Old Mar 7, 2010 | 03:46 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Good point 150.00 for a water pump is not chup change to me..
Old Mar 7, 2010 | 06:03 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
So is the aluminum pump the way to go? or is it a waste of money over a rebuild?
Old Mar 7, 2010 | 06:20 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
the thing i don't like about most rebuilds is the hubs
often have runout-they can wobble a bit,the cause is
the shaft is hardened because the ***** in the bearing
run directly on it,while the hub is softer mild steel,
making it difficult to get the hub pressed on straight.
Some rebuilders will use a special machine to grind
the face of the hub true.
Considering a quality aluminum water pump will likely
last 15yrs or more,i'd say it's worth it
Old Mar 7, 2010 | 08:17 PM
ls six's Avatar
I didnt say you couldnt use it as a core, if they want to give you some cash for your junk pump then great! But with the exception of electric pumps and mebe some high end race pumps you just dont send your old piece in to be rebuilt. That might happen for odd ball motors but for any SBC theres no such service. Buy a good pump and if it goes out in your life time buy another one. If they offer a life time warranty then even better.
I would also not buy a reman either.
Old Mar 7, 2010 | 09:15 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
I had a stewart components stage II. Had it rebuilt twice at $70 a pop. Still leaked. I'm running a Edelbrock now, no problems yet.
Old Mar 7, 2010 | 09:21 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Ok seems like Edelbrock is the way to go, now who has the best price?
Old Mar 7, 2010 | 09:54 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
i bought mine from Northern,forgot what i paid in'98,
but it was well worth it and still going strong
Old Mar 9, 2010 | 07:16 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
short or long? 1992 camaro? summit sells a cheap aluminum pump for like 45.00 ??
Old Mar 9, 2010 | 07:51 AM
Twin_Turbo's Avatar
long
Old Mar 9, 2010 | 09:14 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Old Mar 9, 2010 | 10:29 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Be skeptic on Summit parts. Although I believe their water pumps are Weiand brand, which is good that I know of.
I have a #23123 Stewart Stage 2. I will run a leak test before installing. This pump looks great though, lighter than stock, 30% higher flow and to the guy who said his pump leaked, did you match it with a Stewart Stage 2 thermostat, may this have put stress on the pump with a none bypassed stat being used? (Obviously not the problem if you used their matching stat). Let me know this...as Stewart recommends it due to the higher flow, may have blown something out using a none bypassed stat resulting in a leak, then the rebuild on top of that probably didn't help. Just curious
Old Mar 9, 2010 | 11:12 AM
pondriver's Avatar
Engine: 350 HSR
I bought mine new from an individual and I simply drilled a pilot hole in the stock thermostat. The pump developed a weep drip that blew coolant on my engine. I sent it back and had it rebuilt($70) and also purchased their recommended tstat which had a pilot hole drilled (looked like my stock one) for ~$32.00 after shipping just for the tstat. Pump soon developed the weep again. I tried to get stewart to rebuild it again, they agreed but it was going to cost me another $70 to get it done. It's in a box, in my garage if anyone is interested in it. I purchased the edelbrock and have not had any issues yet.
Old Mar 9, 2010 | 11:47 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Oh okay. Well I'll be sure to get a leak test before installing. Thanks for the review.
Old Mar 9, 2010 | 12:21 PM
pondriver's Avatar
Engine: 350 HSR
Mine may have been a one out. I may have just gotten a bad pump. I'm sure others are running stewart pumps with no problems.
Old Mar 9, 2010 | 12:48 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
I just order my Edelbrock water pump $171.90 total... ouch Summit
Old Mar 10, 2010 | 07:33 AM
ls six's Avatar
If you order a quality pump and keep your coolant in good shape the pump will last tens of thousands of miles, I wouldnt waste my time getting a conventional cast pump rebuilt and I would avoid rebuilt pumps also. If I have to drop another $170 ish after 100,000-150,000 miles then I will.
IMO it's like getting your performance tires re-capped cause you dont want to spend another $500-$1000 every 50,000 miles, you could proabably do it but dose it seem all that smart?
Old Mar 10, 2010 | 07:37 AM
Twin_Turbo's Avatar
It's the same as with shocks and brakes, most people spend tons of money on their engine but buy cheap KYB shocks and such.
Old Mar 11, 2010 | 01:05 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
This is true i have 198,000 miles on my factory water pump in my expedition and i " flush " not just change...my cooling system once a year with the ford factory coolent..
Old Mar 11, 2010 | 05:35 AM
adriyanna62's Avatar
I really like the eldebrock i put on mine back in '98
OEM quality,What lol about it!!!
____________________________________________
Free Poker Money
Old Mar 17, 2010 | 07:09 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
cheap waterpump= 6 yrs strong.
cheap radiator= not so much.
<bangs head on wooden desk for luck>
Old Apr 6, 2010 | 07:20 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
ive had a rebuild stocker i think with 10% more flow that i got 4 yrs ago. 36,000 miles and 2 engines and its still running great. its nothing special, local guy i get parts from got it for me, was pretty cheap and it cools my 383 in hot 100degree weather just fine with a stock rad
i do have to say it weighs a ton tho. if i were to get a aluminum one it would be purely for weight reduction.
Old Apr 6, 2010 | 08:01 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Remachine and install new seals.
Old Apr 6, 2010 | 08:59 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I think Steward is by far the best if cooling performance is an issue. Stewards have the larger and better quality bearings, the better impeller, and are flow balanced for left & right banks.
If it's just for weight reduction, then about any brand should be fine.
I've had one Edelbrock and a Moroso I think with no problems from either.
Rebuilding is a relatively simple task.
Old Apr 7, 2010 | 04:30 AM
Car: 1986 Trans Am
Engine: 5.0
I don't remember the brand name, but there is/was a company that was supposed to have a much better quality pump. similiar to the comment of the Steward's pump. Supposed to have a improved impeller that was supposed to make a huge difference, but it has been many years since I have read about it.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
