Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
305 to 312 stroker???
Old May 17, 2011 | 11:09 AM
speedking1995's Avatar
Car: 1992 camaro rs 25th anniversary
Engine: 305 TBI
i found this stroker kit today and i dont know if i should get it anyone got it? or know anything about it pls help!!
http://www.rpmmachine.com/305-chevro...roker-sb.shtmlhttp://www.rpmmachine.com/305-chevro...roker-sb.shtml
Old May 17, 2011 | 11:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 to 312 stroker???
Would someone really spend that much money to gain 7 cubes?
Old May 17, 2011 | 11:43 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
... 7 cubic inches? Unless you have to stay under some engine size limit for a racing class, whats the point?
Old May 17, 2011 | 11:59 AM
Engine: 305 TBI
i was looking for the 355 kit but i cant find it got the link? and the 312 kit says it makes 750hp but i find that hard to believe suggestions ?
Old May 17, 2011 | 12:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you want to go fast, don't start with a 305 block.
Old May 17, 2011 | 12:14 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
because people think "stroker" means huge gains in hp even if its just 7 cubes
Old May 17, 2011 | 12:15 PM
travis401's Avatar
Car: 91 Camaro RS
750 HP out a 312 cubes...not unless its running a CRAZY amount of forced induction
Old May 17, 2011 | 12:20 PM
Rickey_85TA's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305 (5.0L) TPI
Axle/Gears: 9 Bolt Borg Warner Posi-traction
It doesn't say the kit will produce 750hp.
The parts they sell are rated to handle up to 750hp, if you buy the high end kit.
Old May 17, 2011 | 01:56 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Why would you waste your time and $$$ on that? Start w/ a 350 and go from there, or even a newer dartblock....
Old May 17, 2011 | 02:12 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
The stroker kit is a forged crankshaft with a .02" longer stroke. Save your money and just deck the block to 9.00" (.025 less than stock)
Old May 17, 2011 | 02:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You can build a 312 just by boring .040" over and keeping stock crank.
That kit has some nice parts in it, depending on what you get but your limiting your performance with the small bore and standard 23 deg heads. Unless you spray alot of nitrous, or are trying for a max effort n/a motor with high rpms for fun or for a racing class, or building a boosted project, you dont need a new crank/forged pistons etc.
You can find a 350 block and put the rotating kit towards that. Same price, just different size pistons
Old May 18, 2011 | 11:06 AM
Engine: 305 TBI
the only problem with getting a 350 is i'm low on cash and i cant find a 350 for sale in my area but i have to fix other things before i get another engine but if anyone has a 350 they would sell me for a reasonable price around charlestown indiana then let me know thanks for the advice everybody. also if anyone knows what exhaust system i should get to get a loud badass grunge sound let me know
Old May 18, 2011 | 12:59 PM
strigi86's Avatar
lol 750 hp
thats a really small/pointless growth and contrary to what a lot of people repeat after seeing other people say it, the 305s displacement is not its main shortcoming, look at all the **** ford guys have done with 5.0s or for that matter any european sportscar. You could spend that money on upgrades that open up the 305 and are comaptible with 350s/383s in case you ever move up. 312 would just be a cool number.
Old May 18, 2011 | 01:13 PM
Shadow Z's Avatar
Car: Lots of 'em
Originally Posted by strigi86
lol 750 hp
Yes sir, not even a 5.0. Just a single cam 2 valve little 4.6. I think I'm making just below 300 HP at the crank N/A with an email tune, CAI, and exhaust. I'll be making up to 450 at the crank once my Vortech is on. Could make up to 500 at the crank on the stock short block, with stock heads if I run a front mount intercooler with some decent blower cams.
Gonna do it way better when I get working on the IROC. Mustang has a small engine and boost is on the way. The IROC will have a big engine with boost eventually.
But yeah, this 305 stuff is pointless. Thread title should just be "350 to 383 or 388 stroker???" if he wants some decent power.
Old May 18, 2011 | 03:14 PM
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
Axle/Gears: 9 bolt 3.27
if you need a 350 block... you can have one of my 350 blocks(bare except cam bearings and freeze plugs) for 20$ if you come pick it up
buuut i'm sure the gas to get here would cost more than the summit blocks... regardless
one is a 2 bolt 1 piece rear main from a 92 van nothing was wrong with it
the other is a 4 bolt main 2 pc from an 81 K20 needs to be align bored(spun 1 and 8) but i have a chrome oil pan for it that you can have
Old May 18, 2011 | 03:23 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
The bore on the 305 is way too narrow, for serious power. The ford 302 has a 4" bore, which is easier to work with.
Old May 18, 2011 | 03:46 PM
CAMiroczARO's Avatar
Car: 88 irocz
Engine: 355 tpi
Transmission: tko 600
Axle/Gears: 2.77..for now
dont waste any money with those 305s. they are just boat anchors. 305 is no match vs a 350. torque wins races and thats the biggest difference between the two
Old May 18, 2011 | 04:48 PM
AmorgetRS's Avatar
+1 The displacement is not the problem, it's the tiny bore size.
Old May 18, 2011 | 05:31 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
A 312 is not a stroker...it's a .40 over 305. That said that kit is a waste of money since you are not "stroking" anything. The 334 stroker kit is a REAL stroker kit and is actually pretty cool. Theres a guy that lives around me that did it in his TPI IROC and was running 13.2's all motor on stock heads with the TPI set up still.
Honestly, I have played with 305's. Fun little engines and you can get decent power out of them. If you were to do anything, use your stock 305 and put a cam in it, some headers, and an exhaust. Then save for a 350. You will never make power as easily as you could with a 350 honestly. My brother put 1700$ into a stock 350 shortblock and is making around 440 HP at the flywheel. Theres no replacement for displacement.
Old May 18, 2011 | 06:12 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
go to the junkyard, do a little research on what cars and vins had 350s pull one that seems like itll be good for cheap, if you can hear it run even better, but from a jy you know its complete, and you can modify some alsready factory parts to strengthen them, it would aslo be cheaper. that is no stroker kit, .02 isnt much of any gain, and 750 is what the parts are rated at, cam a 350 and better intake system and your already making better power
Old May 18, 2011 | 11:18 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yes the bore size is the limiting factor. same stroke as a 350 already but a small bore size and cant be bored toa 350. you can run a stroker crank and get a 330 out of this. but for the same cost you can do a 350 built...doesnt make sense to me. and overboring doesnt really do much. I always do the minimum i can possibly do on the overbore as .030 over only add 5 or 6 cubic inches...
Old May 19, 2011 | 06:17 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
save the money and buy a longblock 5.7 roller with vortec heads
Old May 19, 2011 | 07:09 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
right now im working on one of those old 300 hp 307's to see if it was true that they made one hp per cubic inch in some of them, but its out of curiosity, then im building a 400. so there really is no replacement for displacement
Old May 19, 2011 | 11:18 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's a function of airflow, not displacement. One gross HP/cu-in isn't even a challenge.
Old May 19, 2011 | 12:04 PM
Engine: 305 TBI
where do u live and could you ship it?
Old May 19, 2011 | 12:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Summit 383 block isnt a bad deal...
Bore size is a limiting factor with 23 deg heads...however if you look at LS1, they have a small bore size 3.898" but make huge numbers on stock heads. Stock heads may only "flow" 250cfm on a bench when sbc 23 deg heads of similar "cc" size may flow 300cfm and have much larger valves, they still have a hard time outpowering a stock head 346" LS1 car. LS heads with the 15 deg or so valve angle kills 23deg sbc stuff.
Even some 4.125" bore SBC 400's have a hard time doing what a big cammed cam race effort stock head 346" LS1 can do. There are many cam only cars in the 10's.
Even GM's tiny 4.8L with a 3.78" bore will make big numbers. I've seen a local kid cam/LS6 intake a 4.8 and put in a 95 Z28 camaro and run low 12's at 115mph! Thats not gonna happen with a 305 SBC....
The valve angle in the heads really helps flow, especially with the smaller bores. You just wont find those heads available for a 305 sbc bore size....
Old May 19, 2011 | 06:55 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
lets not argue about it, ut in 1970 that was a pretty big feat or such a small displacement, i dont think our cars from factory could do that
Old May 19, 2011 | 06:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check the stats on the 1957 Corvette with the fuel-injected 283. 1 gross HP/cubic-inch.
By making your goal power per volume, you've removed displacement as a factor. A model airplane engine makes about 2.5 HP from 0.4 cubic inches. That's about 6 HP/cu-in.
Old May 19, 2011 | 07:07 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i know, im not arguing, it im just saying not many could do that. i know they were out there, with vettes always being gm's baby they had better than everything else. anyways i understand where your coming from, and well just leave it as that and go back to the stroker discussion
Old May 19, 2011 | 10:21 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
so many factorrs in a good engine. bore size vs. stroke. rod ratio. valve angle. etc. the ls1 has those heads and unique design there. its really unfair to compare the older less advanced engines to the newer ones. in 1970 1 hp per cubic inch was a feat. but its was doable. you dont have all the cam choices now. head choices. manifold choices etc.
Old May 20, 2011 | 12:40 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
zero decked block and 305 Vortec heads wakes up a 307
Old May 21, 2011 | 08:29 PM
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
aurora IL, its not really worth it to ship since they aren't vortec's not really worth the gas for you to get here either probably
GouldyGTR
Sep 7, 2015 09:05 PM
TBRays98
Sep 6, 2015 05:05 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
