Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
March Performance bracket and pulley setup - WHAT IS UP WITH THE ALTERNATOR?!!!
Old May 13, 2012 | 11:58 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I sent a email and pictures to march performance about a question i had on my alternator...
"I bought a setup just like this http://www.marchperf.com/pg63.html but the cheaper silver powered coated kit everything works great and bolted up perfect, only one thing i was a bit confused about is the alternator pulley. it almost seems like the pulley wasn't milled far enough. I couldn't use the lock washer and i could barely tighten the nut. I would say that the pulley is probably held on the shaft by a few threads, it worries me. I even took off the cooling fins and tried to get extra room. when i ordered from summit racing they said everything would work with my setup"
There repose was that some alternators have different sized shafts and that as long as a few threads would hold the pulley on it would be fine and if i was worried about it to use lock tight.
Take a look for your self and tell me what you think?!
Old May 13, 2012 | 12:21 PM
87350IROC's Avatar
Car: 87' IROC
Re: March Performance bracket and pulley setup - WHAT IS UP WITH THE ALTERNATOR?!!!
There is no way I would run it like that. How thick is the pulley at the nut? Perhaps you could mill or turn a pocket for the nut to sit.
Old May 13, 2012 | 12:53 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
"I bought a setup just like this http://www.marchperf.com/pg63.html but the cheaper silver powered coated kit everything works great and bolted up perfect, only one thing i was a bit confused about is the alternator pulley. it almost seems like the pulley wasn't milled far enough. I couldn't use the lock washer and i could barely tighten the nut. I would say that the pulley is probably held on the shaft by a few threads, it worries me. I even took off the cooling fins and tried to get extra room. when i ordered from summit racing they said everything would work with my setup.
Does that pully have a billet cover/cap?
Old May 13, 2012 | 01:04 PM
92 BBC Z's Avatar
I think its supposed to have a different style pulley. I have the exact set up for the electric pump, but for a bbc, and the alterator pulley they sent looks different than yours pictured. If you were supposed to recieve every part in the link, then that pulley in the pic isnt the right one, or like you thought, wasnt properly machined finished, not deep enough and no holes to mount the cap. Did you recieve a cap/cover?
Old May 13, 2012 | 01:20 PM
92 BBC Z's Avatar
Like this.Name:  100_1462.jpg
Old May 13, 2012 | 06:40 PM
FueledSoul's Avatar
My ps pump pulley has 3 holes that are threaded for a cover the alternator doesn't have threaded holes now of the pulleys came with covers
Old May 13, 2012 | 06:45 PM
92 BBC Z's Avatar
I'd say they packaged the wrong alt pulley.
Old May 13, 2012 | 06:54 PM
92 BBC Z's Avatar
Im gonna go and take my alt nut cover off and take a pic. be back in a min.
Old May 13, 2012 | 07:09 PM
92 BBC Z's Avatar
Old May 13, 2012 | 07:13 PM
92 BBC Z's Avatar
I dunno, they look the same...minus the holes of course.
Old May 13, 2012 | 07:19 PM
92 BBC Z's Avatar
One more pic.Name:  100_1463.jpg
Old May 14, 2012 | 11:28 PM
johnf123's Avatar
Car: 1992 RS vert
Engine: forged 383
Transmission: a busted one for now ;)
Axle/Gears: 4th gen 3.73
had the same problem on my RS. i just removed the spacer in between the fan and actual pulley on my stock alt. and it works perfect
Old May 18, 2012 | 06:17 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If your dealing with Summit Racing than you must talk to a Technician at 1-330-630-0240. E-mail him the photo if you must .I would never run any thing that has the potential of seriously hurting me or others. That just looks wrong.
Old May 20, 2012 | 12:18 PM
92 BBC Z's Avatar
So what did you find/figure out about your situation? FueledSoul.
Old May 20, 2012 | 10:56 PM
FueledSoul's Avatar
I think i will send march a link to this thread...
Old May 25, 2012 | 11:44 AM
92 BBC Z's Avatar
Why? What are they saying?
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
Navy8125
Aug 22, 2015 07:13 PM
