OER Dash Pad
Car: 1990 Camaro RS
Engine: L31
OER Dash Pad
I've read some bad reviews about this, but what other choice is there really? I shopped around online for a few weeks until I found the best price. I won't say where I ordered it from unless a mod okays it, but it was 356.16 shipped. The place I ordered from waited two days then drop shipped it from OER.
It arrived well packaged from OER, it was wrapped in bubble wrap with styrofoam spacers to take up the slop in the box. The ends of the box had packaging paper to keep it from moving around. I unwrapped barehanded without a knife so as to not damage the skin on it. It was taped well.
Now onto the comparison. I have read these come without screw holes, they are plastic cored, the speaker grilles don't match and the grain doesn't match. OER must have stepped up their game because mine had screw holes, a metal core, matching speaker grilles and the grain match was perfect. It matched my OE pad exactly.
As to the installation, it went in just like the other one came out. It slipped in easily and the screw holes lined up surprisingly well. I have read about a gap around the center vents but the gap in mine matched the OE one.
Re: OER Dash Pad
This is good info. I have been babying the one in my car with ArmorAll for the last 26 year but even so the plastic is now quite inflexible. Won't take much of any sort of hit to produce a crack. The stories about the less than GM fit of the aftermarket pad didn't give me much hope but your experience relieves my anxiety.
M
M
Re: OER Dash Pad
My OER fit pretty well, my only issues were the corners (where the defrost vents are) didn't lie flat at that angle. It fits a bit better with time and heat. Also at the corners of the front vents it started to depress ever so slightly, it kind of bothered me but it's better than the cracked dash I had before. Ultimately I've covered with with a carpet cover to keep it in good condition.
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Re: OER Dash Pad
Spaceboy, It would be great to see pictures of your new dash, interested in seeing the speaker grilles and such. I am starting my interior restoration and would love to get my hands on a good quality dash,thanks.
Car: 1990 Camaro RS
Engine: L31
Re: OER Dash Pad
Here are some pics.
Top side comparison:
Not much to add here, looks like a clean replacement.
Bottom comparison:
As you can see it does not have the silencer tape the OE pad has.
The OE grille area:
The OER grille area:
Very well reproduced I think, minor dimples at the edge of the recess and the holes are slightly smaller. I did not notice this at all until I reviewed my photos.
OE edge:
OER edge:
Slight difference where it tucks under the A-pillar trim.
Center defrost OE:
Center defrost OER:
The OE doesn't look as crisp here and I believe it is due to the vinyl shrinking. That is not chips in the cut out in the OER, it's light from the bag. The edge of the opening on the OER is perfect.
Bottom comparison:
The OE grille area:
OE edge:
OER edge:
Center defrost OE:
Center defrost OER:
Re: OER Dash Pad
Please PM me where you purchased. I am guessing either Classic or YearOne.
M
M
Car: 1990 Camaro RS
Engine: L31
Re: OER Dash Pad
I'll try to get better ones once it has thawed out some and the sun isn't in such a bad spot.
Edit: PM me if you want to know the supplier. I don't want to break any forum rules or step on any toes. If a mod okays it I will post the supplier.
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: OER Dash Pad
you wouldn't be breaking any forum rules unless you were associated with the seller.
Car: 2000 SS Camaro LS1
Engine: 347 cu in mild mods
Axle/Gears: 3:42 or 4:10 depends on what I'am d
Re: OER Dash Pad
I have seen the OEM pads in person and all I can say is they are just 'OK' if OK suits your needs. The grain in the vinyl doesn't match OE nor does the color and the fit could be much better.
I have a NOS pad still in the original GM box which I'am considering offering 'For Sale'. It belongs on a full restoration, show car, or a VERY NICE driver.
However Gents, I'll say up-front, its NOT cheap if/when I decide to sell.
Here are some pics to compare...........
Re: OER Dash Pad
I first saw a OEM pad about 4 years ago as I recall. The owner was not real happy with it but didn't want to pay 'Just Dashes' in CA around $950.00 to restore his original. BTW, I've also seen their 'restored pads' and they are NOT much better then OEM brand.
Re: OER Dash Pad
I don't like the Just Dashes concept. They put a thin layer of foam over the original dash after repairing the cracks and then vacuum form new vinyl on top of that. It has to come out thicker then original and I have heard stories of fitment issues such as AC vents and gauges due to their process.
Re: OER Dash Pad
A fellow Camaro owner and good friend sent his 1969 Z28 OE pad to Just Dashes to be 'restored'. After spending nearly $1000.00 for the work and shipping cost, he was NOT happy.
He is now searching for a NOS pad which are very difficult to find and VERY expensive should one Pop-Up.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: OER Dash Pad
The OER pad that the OP has is a lot cheaper than Classics.I did try to Order one from them last winter and they were going through some kind of research and development with the FireBird pad,I don't know about the Camaro Dash Pad.
Car: 1990 Camaro RS
Engine: L31
Re: OER Dash Pad
Here is a comparison of the vinyl up close. Tell me this isn't perfect on color and grain.
I didn't get a better one of it installed, I slept the sunlight away. The draw backs of working evening shift.
As to the guy saying it is just OK, keep in mind folks he's trying to sell his NOS one for big money and that may cloud his judgement.
I'm going to take your guy's word that it's okay to post nonsupporting vendor links.
http://www.classicdiscountparts.com/...-Dash-Pad.html
This is where I got it from and I found it by doing google searches for the part number. If anyone else orders one I hope you have the same experience I did, I surely would buy another if I needed it.
Location: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
Re: OER Dash Pad
Great posts and pictures! Thanks for the detailed information. My cars are both show cars, and I will have to look at the OER option when I need a new pad. Right now I don't need a pad for my 82 or my 86, keeping fingers crossed, however it is nice to know what options there are.
I have a NOS bird pad that I bought new from a Pontiac dealer in 1989 for the TA's with Performance Sound that came with the cloth speaker grills. The build date on the item is 1986. Since I have owned thirdgens contiuously since 1982, I figured it would be wise to put back a few parts for the future. Just a few OCD traits going on here... The NOS pads sold for $189.00 in 1989.
Just because one has an orginal pad in the original box does not mean it will last forever. My NOS pad is stored under a bed in a room that never sees over 75F or under 65F. Still, it is 26 years old, and could crack at any time just from age. I had better go and check on it...
Good Info and review on the OER pad.
Charles
Charles
Re: OER Dash Pad
Looks like a pretty decent replacement. Does anyone know if the 82-84 FB pad has the correct grooved lines? The picture on classicdiscountparts is not very detailed. I would buy one of these if it is correct. I have been looking for over 2 years for a good 82-84 FB dash pad that is a reasonable price and not cracked. This would be a solution.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: OER Dash Pad
Car Parts Discount sell it, but they want $389.00 for it and it doesn't come pre-drilled.
https://www.carpartsdiscount.com/aut...ml?3593=127509
So your place is a better option even though there description leaves a lot to be desired. The pad in my IROC is original and is great condition, but it is good to know there are quality replacements out there because I'm sure my dash won't last forever.
Re: OER Dash Pad
Nice to see someone finally selling less than $425 like CI is, and Ricks seems to be higher than that. Have seen Repops going for as much as $675 online.
Thanks to a lucky chance encounter while looking for a drivers door locally, I happen to get my hands on a OEM out of a 1990 that was totaled and it in mint. Owner salvage doors, interior, dash pad, hatch and rear diff...everything else got junked. He let me have it for $40......I hit the lotto with that buy...lol
Re: OER Dash Pad
I did buy a dash overlay prior to this and I can tell you right now, it was without a doubt the biggest wast of $100 plus S&H I could ever have spent. Overlays dont cover the entire corners...so any damage underside is seen.
Re: OER Dash Pad
I am going to invest in a couple of dashmats to protect the dashes in my cars. I had a dash mat in one of my 83's that sat in the sun all day and the dash looked great when I sold the car at 20 years old in 2003.
http://www.car-truck-accessories.com...utm_medium=cpc
Re: OER Dash Pad
Charles
Charles
In the case of auto dash pads, it seems that the sun's UV rays play havic with them. I have personally seen OE pads in 1st Gen Camaros that were well cared for and crack-free after over 40 years.
A good friend is the original owner of a prestine 68 Z28. He applies K-Y jelly to his pad about twice a year. He says DO NOT use a product that is silicone based such as Armor-All because silicone will PROMOTE cracks. K-Y is water based and can be wiped away with a moist cloth which is what he does when he shows the car.
Don't laugh about the K-Y jelly - it works.
Re: OER Dash Pad
Also, the OEM pad is way too glossy.
However, if you are happy with your repop pad thats Great! Its your car.
Re: OER Dash Pad
The 'padding' in the originals is indeed urethane. The covering is vinyl.
Car: 1990 Camaro RS
Engine: L31
Re: OER Dash Pad
Ah, I see what you mean there. When I took those pics the pad was covered in mold release, it was very oily. The grain is a dead match, there is not a different grain pattern from one spot of the dash to the other. My comparison shot would be consistent on any part of the pad, weather it is around the speaker or the vent.
I hope you didn't think I am taking a dig at you. I took no offense as you were judging the OER pad and not me.
Re: OER Dash Pad
It is this type of discussion and critical analysis which will hopefully force the after market/repop parts to become much better. This has happened with the 1st gen F-bodys as well as the 'Vette Guys. And believe me, both groups are VERY critical and rightfully so when one considers a numbers matching 69 Yenko Camaro or a 63 ZO6 'Vette in the same condition.
Thanks for clarifiying the mold release agent on your OEM pad.
Re: OER Dash Pad
No offense taken at all and yes I am judging the pad and certainly not you.
Re: OER Dash Pad
The original tooling used to manufacture the factory installed parts in most cases is long gone. Most likely sold as 'scrap metal' years ago.
Mr. 82tarecaro: The OER catalog description is a good example of mixing words. Yes, the outer covering which is vinyl, is vacuum molded around the base (padding) of urthane. It was all done in a large machine by the suppliers that contracted to GM during the time period of production.
Keep in mind that there is a thin piece of mild steel in the pad that serves as the 'base' upon which the urthane and covering is applied.
Thank you for your thoughtful and knowledgeable replies......
Re: OER Dash Pad
You'll be waiting a long time for that, then. Our particular group of car enthusiasts are the cheapest I have ever seen. The fact that Classic even bothered to make a repop dash is a miracle on its own. I have one, no, it's not perfect, but it's better than the cracked and hard dash I replaced.
Perhaps thats the reason you chose to live in 'The Toilet Bowl' of southern CA per your profile also known as LA, CA. Sometimes referred to as 'The Dirty Armpit of America'.
There are many 3rd Gen owners all over this Great Nation of ours that are Very Proud of their cars and working Darn Hard to maintain, fix, and restore them.
Ask me how I know..................
Re: OER Dash Pad
How so? I take a lot of pride in my car. I love third gens, but as a group, we do not spend money. How many people opt to cut a "trap door" to change their fuel pump? Ours cars are neglected and I'm seeing less and less nice examples every day. The fact is we're lucky we even got the dash, because I'm sure they've hardly sold any. Is it SPOT on perfect? No, but its better than NOTHING, which is what we had before.
#42
Re: OER Dash Pad
This is one reason I don't like OER which means 'Original Equipment Replacement'. They mix words in a attempt to confuse buyers into thinking they are buying GM made repop parts which is NOT TRUE at all!
#43
Re: OER Dash Pad
You are both right. Look at the thread going on now by somebody that crammed a Chrysler radio in his car because he had one lying around. Looked like crazy, but hardly anybody had the sense to tell him so
#45
Engine: 5.0 EFI
Re: OER Dash Pad
My GM book says you can test weather it is vinyl or abs plastic,(for painting purposes)you have to get a pin and heat it until it glows red,then stick it to a piece on the underside or hidden area,it will melt some on the pin,then bring it back and hit it with the torch it will give off a Green or Turguoise flame if it is Vinyl, if it's ABS Plastic it will have black smoke and Polypropylene has no smoke at all.So the interiors only have 3 different kinds of plastics,
Polypropylene,Vinyl and ABS.
#46
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: OER Dash Pad
The replacement dash looks pretty good. Did you have any "issues" mounting it?
Dash pads get brittle and crack because the sun bakes the plasticizer out of the vinyl the plasticizer is what keeps them flexible. Keeping KY jelly or some other protectant (I use furniture polish) on the dash along with a dash mat (carpet) will help protect them. Just remember that subjecting any dash to extreme temperatures can and will hurry their demise. This looks like a great replacement at a reasonable cost. I hope that if anyone else buys one that they post a review. Thanks for sharing!
#48
Engine: 5.0 EFI
Re: OER Dash Pad
Did you use those rubber center pieces when you installed the new one,for some reason FireBirds don't
#49
Re: OER Dash Pad
I tried finding out the difference between vinyl and urethane dash pads by doing some searches on the net. The best I could come up with is that a vinyl wrapped dash is a 2 stage process where the inner core is formed and then the vinyl is molded on top of the core. The urethane dash is a single process and the same inner core forms the skin of the outer pad.
A good example of this process is a nerf football. It is molded in one shot and the inner core is foam and the outside skins over in the mold.
It is definitely a cheaper manufacturing process but I wonder how it holds up in the long term.
#50
Re: OER Dash Pad
[quote=actarnoff;5427609]How so? I take a lot of pride in my car. I love third gens, but as a group, we do not spend money./quote]
And that is the concern. You claim to take a lot of pride in your car but yet you look for cheap, junk replacemrnt parts?
Heck!, go to the Bone Yard and 'Suck-Up' the Trash if there is anything there which is unlikely.
Garbage In - Garbage Out. Simple as that.
