Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Summit mini starters
Old Jun 3, 2014 | 07:23 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Has anyone tried one the the mini high torque starters that Summit sells? They are not much more money than rebuilt junk they sell at Advance, AutoZone or Napa. Are they worth a few extra bucks?
Old Jun 4, 2014 | 05:58 PM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Re: Summit mini starters
I used one on my car for years, never had any issues. In fact I still have it and it's going with my motor if anybody ever buys it.
Old Jun 6, 2014 | 07:46 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I haven't tried them but usually cheap prices are accompanied by a low quality control or a made in China/ Mexico label just like the AutoZone and advance stuff. Like harbor freight some stuff you buy is great and other is hit or miss. If it has a warranty (over 30 days) buy it and try it out.
Old Jun 6, 2014 | 07:50 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Well, I'm not sure I need a starter now. I just bought a 91 Z28 and sometimes you just hear a clicking noise when you turn the key. Now I'm reading that it may have something to do with the VATS key system not working properly. So I'm in the process of working that out. I think I removed about 25 lbs of aftermarket alarms, remote starters and stereo cable from under the dash last night just trying to get this car to a workable point to diagnose the issue.
Old Jun 11, 2014 | 12:27 AM
383RAT's Avatar
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
I'm using this Summit branded starter. http://www.summitracing.com/parts/SU...0/?image=large
The black is no longer available but the chrome one is. I have been using it for 2 years no problems. It has lasted longer than the power master starter i had before that but the power master was full size and absorbing to much heat from the headers I think hence a quick failure.
Its hard to say on the Summit branded products. My starter experience was great but the Summit branded throttle body was a P.O.S. until I machined a few bits and pieces of it.
Old Jun 14, 2014 | 09:47 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
get a GMPP starter 12606096.
ya can get them from any GM dealer. will work on a small block or big block.
and ya can put it in your pocket its so light.(under 7 LBS)
ya dont have to play with that aftermarket junk/parts work 100% can crank a 15 to 1 eng over like nothing. (and its made by GM)
http://www.gmperformancemotor.com/me...talog-2014.pdf
page 164
Old Jun 14, 2014 | 10:29 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
page 164
What do they get for one of those?
Old Jun 14, 2014 | 10:43 PM
the last one i picked up from my GM dealer. i paid $130.
bolt in no shims works 100%
still working going on the new eng as well.
Old Jun 19, 2014 | 03:01 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I bought a ministarter from Skip White's ebay store. It's from China, but he's been selling the same model for years now. The store is whiteperformance1 on eBay, and I think they're going for $70 shipped.
Mine works great. I did need to add one of the single shims to the block surface, none to the starter case.
Old Aug 4, 2014 | 09:43 PM
crystal383's Avatar
I'm running one now. It works great! I bought my first one and after a month it went out. But this one has lasted very strong.
The only thing is the shim kit wasn't enough. I had to put a good half inch gap between the block and the starter using washers. But it works great
Old Aug 5, 2014 | 04:56 PM
Beater79TA's Avatar
page 164
Sounds like you had better luck with GM parts than I did. The first 3 I ordered from GM were DOA and would not pass the basic starter test before I would leave the parts counter with it.
Old Aug 15, 2014 | 01:01 PM
92GTA's Avatar
I've always ran a brand new (not rebuilt) GM LT4 high-tq mini starter, specifically with the Denso solenoid, not the Bosch ****. It rocks. I'm on my 2nd one in 14years only because my first one was cracked in an accident involving a rock slide on a mountain road :/
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
school boy
Oct 22, 2015 11:47 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
