Good build abuseable combo for a 350 small block?
Car: 1990 suburban
Axle/Gears: Dana 60 4.11
Okay so im looking to figure out a good strong build for a 350 that will take lots of abuse but stay strong. Im building it for a suburban with 35s. It has a new 700r4 trans with a bnm shift kit. The rear end is freshly rebuilt with 373 gears in it but im planning to swap them for 4.10s. I habe a 4 bolt main bare block waiting to be built but im not sure what all i should put in it. Any thoughts?
Re: Good build abuseable combo for a 350 small block?
And in terms of the rest of the driveline...if you are keeping the stock 10bolts you might have issues. Large tires+aggressive driving will be torture on those stock axles. Rebuilt or not. Also check out ck5.com for any square body specific questions you have.
Tunedports1002
03-22-2011 04:53 AM
Fastcamaro87
02-06-2001 03:52 PM
