Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Trick Flow Heads
Old Jan 1, 2021 | 03:07 PM
Alan B's Avatar
Car: 1983 Trans Am; 1977 Trans Am
Engine: 305 HO; Poniac 400
Transmission: T-5; Turbo 350
Axle/Gears: 3:73, 3:23
Trick Flow Heads
Has anyone installed the Trick Flow heads for the small bore 305? I have a 1983 TA with the 305 HO motor and was considering these. Would like to know if anyone is running them and what kind of performance gains they realized,
Old Jan 1, 2021 | 03:17 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Trick Flow Heads
I haven't seen them run but your choices for small bore is slim. Holdener did a video on his tests
Old Jan 1, 2021 | 03:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Seen a few builds. One or two guys on here had them on 305 or 334 strokers
richard holdener made some decent power with them, 612 with boost
Old Jan 2, 2021 | 10:53 AM
Alan B's Avatar
Thanks - this is helpful!
Old Jan 2, 2021 | 05:11 PM
BadSS's Avatar
I haven't seen them run but your choices for small bore is slim. Holdener did a video on his tests https://youtu.be/K8nKXfS6sUA
Those .050 duration and lift specs are for a 268XFI, so is the cam that or the XR274? Maybe it doesn't matter in the grand scheme of things, but I don't think he keeps very good documentation. This is not the first inconsistency with his recollection of or info provided on videos of older build.
That said, I think the TFS 175 heads are great heads for a 305. Helping a friend with a remote build and that's what he ended up going with.
mw66nova
Apr 6, 2003 08:52 AM
fbody83
Mar 23, 2003 02:14 PM
RSCamaroGuy92
Jul 17, 2002 03:46 PM
RMK
Apr 11, 2002 08:14 PM
