If you plan on ordering the SLP cold air box ONLY...
Car: 2004 GTO
You don't need to order the lid too. It already comes with one. Now I have an extra.
Damn....there goes $17.
Car: 2004 GTO
The cost to ship,restock and whatever else would cost almost as much as the part itself. So I'll keep in case the lid cracks.
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
what else besides the box?
i'm wanting to purchase the airbox only from the slp cai kit P/N: 21015.
do i need to buy anything else, like P/N: 21021 or P/N: 21017 to have it work on application (89 trans am). (these are extended wiriing harnesses for the vac. can and MAF)
not sure where there's room for the vacuum canister or if the MAF is moved when just putting in the box.
anybody have some pix with just the box?
thanks!
- del
thanks!
- del
Car: 1988 Formula 350
Transmission: 700R
Axle/Gears: 9 Bolt...3:27
I have a 1988 Formula 350. Just ordered the box. Bought the vaccum hoses and extended the wiring harness as I placed the cannister in the nose. There is a brace there that I hooked up to with a LARGE hose clamp. In there tight and out of the way. You can see the brace thru the opening where the latch closes for the hood. Not hard to get to at all from underneath.Using the stock air passage hoses and fits perfectly on the box. MAF stays where it is.
1992rs/ss
16
Jan 28, 2016 09:58 PM
kyle5647
Aug 15, 2015 11:56 PM
db057
Aug 11, 2015 10:11 PM
