WTF help please
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
WTF help please
Ok so I strapped on my stralth ram yesterday it took me all day but I got everything done now it starts fine revs up then chuggs and dies im thinking air leak but I don't know any help is appreciated
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
check for vaccum leaks
depending if he has an adjustable regulator or not
other way
Car: 89 Formula
Ohh ok that may help also I tore it apart and found an upper to lower gasket was ripped (damn cheap thing) so I had to order some thank you all
Car: 89 Formula
Just to update I had my car to the track today and did pretty well and have decided that TPI is for tow rigs and 4x4s not performance cars
what were your times and what mods do you have
Car: 89 Formula
I was cutting 14.0s at about 100 mph with vortec heads stealth ram tes and cat back that was in the heat of the day with a really soft launch I picked up a half second with the intake swap so I was more than pleased with the results
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Good luck!
-- Joe
Car: White KSwisses
Engine: 5.3L Gen III
Originally posted by 1989GTATransAm
Check out my 4x4 or tow rig in my signature. Bwahahahahahaha.
Car: 89 Formula
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah thats a seriously built car with alot of $$$ in it that would probably make more power with a different intake if you into that thats fine you can have it
I had a 355 with 8.9:1 compression, iron heads, stock tpi, flowtech headers, cats, etc, etc that went 12.80 @ 105.
I added a blower, and it went 12.60 at 110..
I added a singleplane manifold, and it went 12.40 @ 119.
Once your trapping 110+ it's a real fun car.. After 120, its just plane fast! If I can keep my new setup running long enough without breaking stuff, it should trap around 130.
-- Joe
Car: White KSwisses
Well, note where Allen (1989GTATransAm) and I are from...
We are very limited to what we can run here, so we make the best of what we got.
Its either highly modded TPI or super ram unless you are willing to fork over major $$$ for an entire LT1/LS1 swap.
Car: 89 Formula
Originally posted by anesthes
Yeah, with a decent intake it would prolly trap something closer to 110mph..
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I guess you can't get away with that in california huh? That really blows
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah your cars bad *** everybody knows
It really is amazing how well an engine works with the right intake and head combination.
-- Joe
Car: 89 Formula
Actually my car is a POS and I hate it, it's just the engine combination that works "badass". The car is just another twisted thirdgen..
-- Joe
-- Joe
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
BTW Z69, have you priced 67-69 Camaro's in Bako lately???? You are talking 7G's for a piece of junk these days, basket cases are going for 4G's..... I've owned three 68's and three 69's including a convertible. If I only knew then what I know now...........
gta892000
Sep 16, 2015 12:37 AM
