Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
GM RamJet hood clearance
Old 10-14-2005, 12:04 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
Has anyone used a GM RamJet manifold? I'm wondering if there is enough room between the manifold and the hood for my strut-tower brace. I'll be using a stock flat hood.
I've seen the magazine article where GM had a RamJet in a yellow Camaro, but it didn't have a STB.
Old 10-15-2005, 06:12 PM
bennyhonda's Avatar
Car: 1992 Camaro RS
I would say no, judging by the dimensions. The Ramjet is 9.75" tall and my Edelbrock STB is about the same height and slightly contacts the underhood padding.
Attached Thumbnails GM RamJet hood clearance-manifolddiamentions350ramjet.gif
Old 10-17-2005, 12:14 PM
Axoid's Avatar
Car: 92 Camaro RS
Thanks for the info.
Old 10-22-2005, 01:41 PM
Camaro_nut's Avatar
I have the Ramjet system in my car. It does not clear
the stock Camaro hood. I had to cut a few braces in the
hood just to clear it. A few people here said that it does
clear easily, but most said it does not. I guess it depends
if you are using stock or poly. motor mounts, factory or
aftermarket K-members, etc. I have poly. motor mounts
with factory K member.
P.S. There is NO way to use the Ramjet intake AND
the strut tower brace under a factory Camaro hood.
You would probably need at least a 4" cowl hood to
clear both. Plus the strut tower brace would need to
be shimmed up to clear the Ramjet intake. Even with
a cowl hood, the strut brace mounts on the strut towers
may not even clear if they are shimmed up.
Old 10-22-2005, 11:05 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
hey Axoid.. what wheels are those, size, and where did you get them? they look awesome
Old 10-24-2005, 03:57 PM
Camaro_nut's Avatar
Ever hear of "PM" aka Private Message?
Old 10-24-2005, 11:17 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
yeah ive heard of it... ever heard of STFU??
Old 11-12-2005, 11:58 AM
5.7tpiroc's Avatar
Car: 89 Iroc
Engine: 5.7tpi
Axle/Gears: 9 bolt posi w/ 2.77s
hey camaro_nut, how much did the whole setup cost you and where did you get it from? did you use the stock computer or did you have to buy a new one?
Old 11-13-2005, 05:06 PM
Camaro_nut's Avatar
The motor comes with ECM. You can buy that motor anywhere.
You can buy any GM performance motor anywhere. Places like
Summit, Jeg's, etc. Even your local dealer can order it. But
the dealer WILL gouge ya. The cheapest place I found was
Jeg's, at the time. Summit now sells it for about the same price.
The whole setup , including the T-56 swap was A LOT!!!!
Old 11-13-2005, 05:08 PM
Camaro_nut's Avatar
Yes, MANY TIMES!!!!! But I never do!!!
Old 11-16-2005, 12:38 AM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
lol, does the ram jet setup use vortec heads?
Also, i think those wheels are ccw's if i remember correctly.
thanks
anthony
Old 11-16-2005, 12:41 PM
Axoid's Avatar
Car: 92 Camaro RS
Yes they do.
Old 11-16-2005, 03:12 PM
Camaro_nut's Avatar
thanks
anthony
Yes, they do. (again)
Jorlain
Exterior Parts Wanted
06-29-2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
Quick Reply: GM RamJet hood clearance
