Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Dyno graph of an HSR 305
Old Jan 30, 2006 | 05:59 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
224hp and 247ft/lbs of torque
'91 305 HSR + lt1 cam. Everything else is completely stock. The log manifolds and stock program included. If you look at the AFR graph at the bottom you can see that with stock tune it gets pig rich from 2500 up until 4500. Just poping this up here to help anyone. It's definately an overkill manifold for the 305 but does provide a very broad flat torque curve.
Opinions? Thoughts? Anyone else dyno'd their HSR 305? With tuning and full exhaust I'm sure you could squeek out quite a bit more.
Old Jan 30, 2006 | 12:37 PM
cheyenne383's Avatar
Car: Huffy 10 speed ;)
Engine: My legs
Transmission: My wrist
Axle/Gears: Little spokey things
I'm impressed with how flat the torque curve is with the shorter style runners in an HSR, not to mention it's a good bit higher than where a cam/intake 305 should be.
Old Jan 31, 2006 | 04:05 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I was suprised as well. I've always heard the "you'll lose the power down low" but it seems pretty flat to me. I kind of wish I saw what it was before the HSR.
Old Feb 1, 2006 | 12:14 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Throw some headers on there and it'll lean out a bit. Tune it and things will get a lot better. That combo has a lot to gain from a tune and full exhaust.
Also, short runners have been known for a long time now to produce a flat torque curve (a la LT1 and Miniram). Longer runners will typically produce more torque, but with a fairly steep curve (like stock TPI).
Old Feb 1, 2006 | 07:11 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I'm surprised that the peak HP did not carry up higher in the rpm range. It appears to me that peak power comes in at approximately the same rpm as a TPI.
Old Feb 1, 2006 | 07:50 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
It might with headers and a decent tune. Who knows. Even after those two things I doubt I'll be rapping it out that far though. It's still the stock bottom end and I barely trust it at 5.5k let alone any higher.
Old Feb 3, 2006 | 06:29 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
thats pretty cool
Old Feb 3, 2006 | 11:44 PM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
That's pretty impressive.
Clean up your fuel issues and you'll see more power.
If I ever do another EFI build up it'll be with a HSR.
Old Feb 5, 2006 | 07:01 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Not enough cam head or exhaust .. that would wake her up
Old Feb 5, 2006 | 08:46 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
So, why is it running so rich?
With the stock programming coupled with the HSR, it should be running lean.
There most be other mods.
Old Feb 6, 2006 | 12:28 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: Dyno graph of an HSR 305
Othat than that, nothing. Stock style bin with EGR removed.
Old Feb 6, 2006 | 09:03 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
What about the injectors? Are the stock 19#/hr injectors still in the fuel rails?
Old Feb 6, 2006 | 11:26 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Yup. Well they're whatever came stock with the car. And the car was absolutely bone stock down to stock style ac delco plugs when I bought it. The previous owner didn't know anything about the car.
Old Feb 28, 2006 | 11:19 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Its rich from 2500-4500 because thats where the tpi's charging effect lies.
Old Feb 28, 2006 | 12:21 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Are you talking about the "tuned" portion of tuned prt injection? Does it really make that much of a difference? Or is that just richening in the stock chip?
Interesting....
Old Mar 1, 2006 | 02:14 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Well, it is just richening in the stock chip and yes, it is there to go along with the added air that the tpi provides in its tuned range.
Magman
29
Sep 12, 2015 10:41 PM
angel2794
Sep 8, 2015 06:22 PM
355tpipickup
Aug 29, 2015 10:47 PM
ASE doc
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
